Guinea pig new RC Long Arm kit? - Page 25 - JeepForum.com
post #361 of 504 Old 03-31-2013, 04:25 PM
texlurch
Those with 6 inch springs; what is your rear fender height? Mine seems pretty tall, but it may just be where the stands are under the front. Allowing some of the weight to tilt to the front a tad?
Anyhow, here are a couple pics, getting ready to start on the front.
Couple of what I did to fit the IRO high clearance crossmember on it with the RC kit.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #362 of 504 Old 03-31-2013, 06:33 PM
oaklyjeep10
I've got 4" and BB. I'm sittin at 39 1/4 in front and 38 1/4 in the rear.
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq
oaklyjeep10 is offline
post #363 of 504 Old 03-31-2013, 07:17 PM
texlurch
I searched and found some hub to fender numbers.. I am sitting 2 inches higher than most with 6 in lifts.
These are 6.5 inch IRO coils, and I figure they will sag some once all the weight is back on and I drive around the block.
I'll wait on ordering the rear shaft until it all settles.
All my isolators look perfect, so I bought the new ones for spares.. LOL!
texlurch is offline
post #364 of 504 Old 03-31-2013, 08:15 PM
oaklyjeep10
Excuse me. Make that 23" in the front and 22" in the rear. What were the numbers u found?
post #365 of 504 Old 03-31-2013, 10:43 PM
PhantomWJ
2003 WJ
Are you sure.
PhantomWJ is offline
post #366 of 504 Old 03-31-2013, 11:30 PM
texlurch
Stock from the factory was 18 front 19 rear. Unless it's upcountry, then it's 19/20 respectively.
Average IRO 6.5 lift is 24.5 F 25 R.
I left my numbers in the shop so I'll look again tomorrow; I want to say my rear hub to fender is 27 right now.
texlurch is offline
post #367 of 504 Old 04-02-2013, 06:56 PM
texlurch
Lift is done: still have to swap front swaybar, and do some fine tuning. Drives good on the initial road test
Front hub to fender 24", rear 25.5". Guess the winch is sagging it a tad, and only have 1/2 tank.
Lift specs: RC long arms; IRO 6.5 springs, crossmember, xfer skid, rear sway bar links; Bilstein shocks; Level 8 16 x 8.5 wheels, Duratrac 265/75
Drag link flip, IRO TB drop bracket, RC TB
Still have to do the tie rod flip, inner sleeves, RCV axles, inner C gussets, Eaton E-locker
texlurch is offline
post #368 of 504 Old 04-02-2013, 07:17 PM
Jaketit
Looking good bro. Keep us updated on street ride quality compared to what you had.
Jaketit is offline
post #369 of 504 Old 04-02-2013, 07:46 PM
texlurch
Feels better already, compared to the 198000 miles suspension that came off..
texlurch is offline
post #370 of 504 Old 04-02-2013, 10:10 PM
MWyatt
texlurch, would you be able to use the IRO long arm brackets up front instead of cutting the ones off the RC crossmember? I like the IRO high clearence cross member and it would be easier just to use their mounts.
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline
post #371 of 504 Old 04-02-2013, 11:03 PM
Gunnison
Gunnison's Avatar
2008 WK
Texlurch, looks great, love yor choice of wheels. My parts should start arriveing next late this week. I plan on installing a spacer with the front springx sto compensate for the 200lbs bumper and which I will be haqnging off the frront end. Maybe an extra 1/2 to 3/4 inch?
02 GC Overland, 4" RCLA, 4.5 Clayton Springs w 3/4spacers in front, Bilstiens, JKS Tracbar, Addco rear sway bar, Proto Fab Hi Clearance bumper, Smitty built 8,000 w/Syn
Previous Jeeps: 57 Willys, 74 J-10, 76 J-20, 80 CJ7, 91 XJ, 97 ZJ, 97 TJ, 00 TJ, 06 LJ Rubicon, 2010 JK Rubicon 4dr.
Gunnison is offline
post #372 of 504 Old 04-02-2013, 11:09 PM
texlurch
It would depend on the spacing compared to the RC rod ends.
The low point on mine is now the transfer case skid. The IRO crossmember sits way above it.
Since I was using the RC kit it was just easier than trying to mix and match more mounts. I know you can't move the mounts much farther forward, at least using the RC arms. Even with the 6.5 springs the ends are almost bottomed in the arms. And you can't go back without interfering with the crossmember.
texlurch is offline
post #373 of 504 Old 04-02-2013, 11:12 PM
texlurch
I would say at least a 3/4. I got my springs and shocks used, with low miles, so I don't know what the previous owners setup was. I only had 1/2 tank, but the fullsize spare, hi-lift and tools are in the back and it still sits 1.5 inches higher. All my isolators are in excellent shape as well, surprisingly.
If you need some new ones I have a complete set.
Once I get my flares on and it warms up, I'll paint the cladding and bumpers matte black to match the wheels.
texlurch is offline
post #374 of 504 Old 04-02-2013, 11:15 PM
MWyatt
Good info, I might end up doing the same thing. Did you end up welding the mounts to the IRO crossmember?
MWyatt is offline
post #375 of 504 Old 04-02-2013, 11:20 PM
texlurch
Nope, they are welded to the frame around the front and rear, and in the large hole in the middle, and the crossmember bolts on top/bottom, sandwiching to the frame.... so the crossmember is removeble without touching the suspension. If you don't want to weld, the two bolts in the front would hold the mounts in place when the crossmember is out.
I have a SYE as well so there is no need for any transfercase drop, but...
Due to the mounts being between the crossmember and frame I did end up with a 1/4 inch drop..
I ended up welding the rears as well; just couldn't see drilling 4 extra 1-1/4 holes in the side of the frame.
texlurch is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 03:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 01:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 07:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-11-2011 12:57 AM
