Guinea pig new RC Long Arm kit? - Page 24 - JeepForum.com
post #346 of 504 Old 03-29-2013, 05:20 PM
sandfreestyle
What I ran into with my RC discos is that the shank of the bolt is smaller than the hole in the swaybar so if you ever happen to get it loose then it makes noise. Just my personal experience though.
04 WJ V8 HO, 545rfe w/ shift kit, NP231HD w/ SS SYE, TW drive shafts, 4" RCX, 255/75/17 moabs, 55w HID projectors, Cherry Bomb Vortex muffler, Superchips, bored TB, HD Tie rod and Drag Link, IRO Steering Equalizer, Dual steering stabalizers, Homemade Sliders, 4 Hella FF75 55w HID Light bar...
“The corpse’s crimson bitter tears flow and mingle through the endless sand feeding the chaos in me and making me stronger”
sandfreestyle is offline
post #347 of 504 Old 03-29-2013, 05:24 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Originally Posted by oaklyjeep10 View Post
Ok guys, quick question. I want to put 6.5" springs in, how do I know how much to adjust everything?
Just play with the lower arms until your axles are where you want them, then adjust the uppers accordingly to get a happy medium between caster and pinion angles.
~James
ezflip is online now
post #348 of 504 Old 03-29-2013, 05:59 PM
PhantomWJ
2003 WJ
Dude, 6.5" is over rated. Go for custom 8" springs.
PhantomWJ is offline
post #349 of 504 Old 03-29-2013, 09:53 PM
texlurch
Originally Posted by aestrad1 View Post
Looking at the route as well. What did you do about sway bar discos?
Discos for the front and spacers for the back come with the LA upgrade; I have the IRO 6.5 springs, Bilsteins and the RC LA kit.
The LA upgrade kit does NOT include an adjustable trackbar, so make sure you get one!
I went with the IRO rear swaybar links instead. I am also using the high clearance IRO crossmember and xfer case skid. So far looks like it will all go together the way I planned. Should have the rear half done tomorrow, and I'll take some pics once I clean up the cuts. My plasma cutter took a crap so I had to break out the torch...
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #350 of 504 Old 03-30-2013, 09:28 AM
oaklyjeep10
So basically just eyeball it? Is is normal that I can barely clear 32s when I have 4" springs and 2" spacers? I'm thinkin maybe the springs are sagging or something, idk maybe it's just me lol.
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq
oaklyjeep10 is offline
post #351 of 504 Old 03-30-2013, 09:42 AM
Jaketit
Just a few more pennies and ill be ordering my RC long arm kit. Yay!! I have the 4 inch springs and 2 inch pucks in also. I'm definitely gonna order some other 6 inch springs when I go for it though. I've seem to notice in the year and a half I've had this lift that the RC springs are sagging also.
Jaketit is offline
post #352 of 504 Old 03-30-2013, 09:54 AM
Gunnison
Gunnison's Avatar
2008 WK
After having two Rubicons with the electric dico disconnect I got spoiled. My current TJ is running the Currie Anti Rock and am loving it. So I am not real excited about going back to convention disco, so that made me decide to not up-grade to the JKS just yet and will use the RC ones that come with the kit.
Once I have the front bumper off to install the new winch bumper I will take a hard look at things and see if there is any way to modify and fabricate a Rubicon electric disco or maybe another anti rock. If too complicated we will see how the RC ones work and go from there.
02 GC Overland, 4" RCLA, 4.5 Clayton Springs w 3/4spacers in front, Bilstiens, JKS Tracbar, Addco rear sway bar, Proto Fab Hi Clearance bumper, Smitty built 8,000 w/Syn
Previous Jeeps: 57 Willys, 74 J-10, 76 J-20, 80 CJ7, 91 XJ, 97 ZJ, 97 TJ, 00 TJ, 06 LJ Rubicon, 2010 JK Rubicon 4dr.
Gunnison is offline
post #353 of 504 Old 03-30-2013, 10:02 AM
Gunnison
Gunnison's Avatar
2008 WK
Use a tape measure to center the axle in the wheel well as well as your eyeball. you could be off enough from side to side that your eyeball may not pick it up and that can enough to cause long term tire wear (if the axle is no tracking straight) and some handling issues.
This why it is important to set the control arms (both front lowers, both front uppers as a set) from side to side at the same measurement.
Once all completed a 4 wheel alignment with a competent alignment tech that understands your adjustable control arms can double check your work and dial thing in if needed.
Gunnison is offline
post #354 of 504 Old 03-30-2013, 02:48 PM
oaklyjeep10
Yea I got that. I didn't know if there was a certain length to adjust the arms depending on how much lift was added. Thanks.
post #355 of 504 Old 03-30-2013, 02:50 PM
oaklyjeep10
Is there a warranty on their springs or is it just the shocks?
post #356 of 504 Old 03-30-2013, 06:59 PM
texlurch
I added 1/4 inch to all the suggested lengths, and that isn't enough.
Got the rear done and it's TALL
Tomorrow I am working on getting the pinion angle set, and the wheels centered, and the rear truss welded on.
My springs are visibly not vertical, as well as the tires aren't centered.
I would say add at least 3/4 inch to the recommended settings if you are going 6 inch. There is plenty of adjustment available.
texlurch is offline
post #357 of 504 Old 03-30-2013, 07:42 PM
oaklyjeep10
My springs must have nearly 2" of sag then bc mine is adjusted to what the instructions say lol and everything lines up mui bueno.
post #358 of 504 Old 03-30-2013, 07:59 PM
aleet25
2003 WJ
When I did mine this way I was told that you don't want your axle centered in the wheel wells. Your front axle needs to be favoring towards the rear and the rear favoring towards the front. Not too much though, just not exactly centered. When you flex your axles naturally gravitate to the center when they are pushed up. If your axle is already centered your tires will rub the wells prematurely.
aleet25 is offline
post #359 of 504 Old 03-30-2013, 08:01 PM
aleet25
2003 WJ
And I'd say that's not normal. You should easily clear 32's on 6" of lift.
aleet25 is offline
post #360 of 504 Old 03-30-2013, 08:04 PM
SKI_VT
X2 I clear 32's and I only have a BB lol
"You people make it sound like Claytons are made from gold and unicorn bones while everyone else uses PVC and spaghetti noodles."
"The Great Turtle Race! -> Iceland vs. Bushwhacker! -> Place your bets!"
SKI_VT is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
