Guinea pig new RC Long Arm kit? - Page 2 - JeepForum.com
post #16 of 504 Old 06-28-2012, 10:28 AM
PhantomWJ
2003 WJ
Originally Posted by tsneath
It's for my personal jeep. I've been wanting to get another grand cherokee and when I saw this kit came out it was a good excuse to go get another one.
PhantomWJ is offline
post #17 of 504 Old 06-28-2012, 10:32 AM
adavis39
you gonna burn that crossmember on or bolt it like it was designed?
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #18 of 504 Old 06-28-2012, 10:34 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Excellent question. Let us know what you end up doing.
Im getting mine in August. I plan to just bolt it up, and assess things from there. If I feel it needs welded, Ill weld it.
~James
ezflip is offline
post #19 of 504 Old 06-28-2012, 10:38 AM
Dusk53
this thread needs pics
Mah build
East Carolina University
Dusk53 is offline
post #20 of 504 Old 06-28-2012, 10:39 AM
PhantomWJ
2003 WJ
Jeep porn...hold on ladies.
post #21 of 504 Old 06-28-2012, 10:40 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
~James
ezflip is offline
post #22 of 504 Old 06-28-2012, 10:41 AM
PhantomWJ
2003 WJ
This one is BIG!
post #23 of 504 Old 06-28-2012, 10:43 AM
Dusk53
Is this the jeep with specs in sig? If so, i bet those ironman arms look 10x better than the RC stuff in question.
Mah build
Dusk53 is offline
post #24 of 504 Old 06-28-2012, 10:44 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Yay STOCK!!!!!
But RC long arms on 32" KM2s and hopefully and Iceland bumper coming soon.
~James
ezflip is offline
post #25 of 504 Old 06-28-2012, 10:46 AM
adavis39
i think it requires drilling a pretty big hole (1 1/4'') into the unibody frame. i would think it would be easier to just go ahead and weld it on but im interested to see some pics of this set up
TNJEEPS.COM
BUILD:
adavis39 is offline
post #26 of 504 Old 06-28-2012, 10:48 AM
tsneath
Not sure yet if I I will bolt it or weld it on there.
tsneath is offline
post #27 of 504 Old 06-28-2012, 11:08 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Yeah, it seems like a fairly large hole, but that section of the uniframe is pretty stout. If you really wanted to, you could drill two much smaller holes an inch and a quarter apart. That might help the integrity. All the hole is for is to insert the flange nuts...
~James
ezflip is offline
post #28 of 504 Old 06-28-2012, 11:23 AM
adavis39
im sure design wise its fine...i just like the peace of mind knowing its welded on..of course if you cant weld or dont have access to someone who does bolting it would be easier
TNJEEPS.COM
BUILD:
adavis39 is offline
post #29 of 504 Old 06-28-2012, 11:28 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
And being the least expensive kit on the market, it designed to be geared toward the budget minded and novice installer. Instead of having to pay a welder $100+, there is the option of bolting it on for free.
I am really interested in seeing the rear a-arm. So, tsneath, when it arrives, take lots of pics before the install. And during the install. And after the install. And when you take it out to try to break it.
~James
ezflip is offline
post #30 of 504 Old 06-28-2012, 11:38 AM
bradywgn71
bradywgn71's Avatar
http://www.roughcountry.com/images_l...ng-arm_908.jpg
I don't see a removable center section on that cross member. It looks like you'll have to remove the entire cross member including dropping your long arms to remove the transmission if it's ever necessary. Welding the cross member will make it much harder to service.
bradywgn71 is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
