Guinea pig new RC Long Arm kit? - Page 16 - JeepForum.com
post #226 of 504 Old 02-11-2013, 08:58 AM
PhantomWJ
2003 WJ
Originally Posted by aleet25 View Post
no, not yet. It's been raining here and i refuse to take this thing offroading through the mud anymore after all the dirt i encountered underneath my rig that i thought i'd cleaned out.
booooooo. :thumbsdown:
PhantomWJ is offline
post #227 of 504 Old 02-11-2013, 09:20 AM
aleet25
2003 WJ
Now hold on...I didn't say I was turning it into a mall crawler. I just won't be taking it through anymore mud if I can help it. I'm surprised my whole undercarriage wasn't rusted through there was so much dirt and water stuck up in there.
aleet25 is offline
post #228 of 504 Old 02-11-2013, 09:03 PM
Roger005
Any alternative to securing the rear long arm brackets after a few flag nuts snapped off?
Thanks
Roger005 is offline
post #229 of 504 Old 02-12-2013, 04:07 AM
aleet25
2003 WJ
Thanks
I welded mine on.
aleet25 is offline
post #230 of 504 Old 02-12-2013, 09:38 AM
Roger005
Any other option? I got some to hold good.
Roger005 is offline
post #231 of 504 Old 02-12-2013, 02:01 PM
tommyooooooh
Im gonna try to make new ones that are a little bit thicker. I had the same problem with 1 of mine bending after it was half way tightened. What a PITA it was to get that out. Rough Country charges $5 a piece for those weak things.
tommyooooooh is offline
post #232 of 504 Old 02-12-2013, 03:39 PM
Rockhauler68
2003 WJ
The threads were full of paint on mine so after bending the first one I cleaned the rest with a tap, no more problems.
Rockhauler68 is offline
post #233 of 504 Old 02-12-2013, 04:38 PM
aleet25
2003 WJ
This may be a complete coincidence that its happening a couple days after I put my lift on, but I started to get a grinding/rubbing noise from under my drivers seat while I accelerate. Any ideas if what it could be? TC issues?
aleet25 is offline
post #234 of 504 Old 02-12-2013, 04:46 PM
bradywgn71
bradywgn71's Avatar
Take off your front drive shaft and see if the noise goes away.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #235 of 504 Old 02-12-2013, 04:56 PM
aleet25
2003 WJ
If it does I'm assuming my u joints are bad.
aleet25 is offline
post #236 of 504 Old 02-12-2013, 06:44 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
I broke one on the rear and called them up to get a replacement. They overnighted me a whole bag of them for free. So I have like 9 spares now
~James
ezflip is offline
post #237 of 504 Old 02-13-2013, 09:55 AM
Roger005
How long did you guys set your quick discos?
Roger005 is offline
post #238 of 504 Old 02-13-2013, 10:00 AM
adavis39
until your sway bar points UP at approx 30 degrees
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #239 of 504 Old 02-14-2013, 11:22 AM
Roger005
Thanks! I am like 95% of the way done with the install except they didn't send me the metal bushing for the heim joint on the track bar so that is the only thing holding me up! Kinda frustrated!
Roger005 is offline
post #240 of 504 Old 02-14-2013, 02:41 PM
aleet25
2003 WJ
I set my lower rear arms and my upper arm to the lengths that came in the instructions, but I think they are too long. My upper and lower spring perches aren't lined up. It looks like my rear axle is too far back. Is it just me? Or does this loom wrong?
aleet25 is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
