Guinea pig new RC Long Arm kit? - Page 14 - JeepForum.com
post #196 of 504 Old 02-04-2013, 09:21 PM
Roger005
So I should probably go with like 4.5 to 5* ya think?
Roger005 is offline
post #197 of 504 Old 02-05-2013, 09:02 AM
WJlover
so how well liked is this kit?
im trying to find the best bang for my buck (a small buck) and if this kits good i might consider a cheaper RC kit.
WJlover is offline
post #198 of 504 Old 02-05-2013, 03:33 PM
aleet25
2003 WJ
Originally Posted by ezflip
Darrell is kind of an idiot. Ive talked to him a few times and now I ask for someone else when I call haha.
My caster is set at 4.1 right now, but im going to raise it to 5 - 5.5. Steering is just a little bit sloppy right now. Before I got my alignment right after install it was at like 9 and was super tight, just had lots of driveline vibes.
You're right. Darrell is an idiot. I called and talked to two different guys just to make sure and they both said that the shocks are only designed for the 4" lift.
To the guys that have installed this lift themselves...how hard is it? I really want to spend the weekend doing it, but everybody tells me I'm crazy when they see the instructions. It says 6-8 hrs. Is that about right?
aleet25 is offline
post #199 of 504 Old 02-05-2013, 07:54 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
It took me 36 working hours over the course of 2 weekends. But I ran into a lot of problems. If everything goes smoothly, you should be able to do it 10-12. 6-8 is really generous.
~James
ezflip is offline
post #200 of 504 Old 02-05-2013, 08:07 PM
aleet25
2003 WJ
36 hrs!?! Good grief! This is my DD. I can't afford to be down that long! The lift gets here tomorrow. Hopefully I'll be able to get all the joints put together by Friday afternoon and get started on the whole process and get it finished Saturday.
aleet25 is offline
post #201 of 504 Old 02-05-2013, 08:27 PM
Roger005
My caster is set at 4.1 right now, but im going to raise it to 5 - 5.5. Steering is just a little bit sloppy right now. Before I got my alignment right after install it was at like 9 and was super tight, just had lots of driveline vibes.[/QUOTE]
The guy from RC told me to get as close to 7 degrees as I can?
Roger005 is offline
post #202 of 504 Old 02-05-2013, 08:47 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
The guy from RC told me to get as close to 7 degrees as I can?[/QUOTE]
It should be as close to factory spec as possible without getting driveline vibes. IIRC factory spec is around 6-7.5. Or something like that.
~James
ezflip is offline
post #203 of 504 Old 02-07-2013, 03:48 PM
tommyooooooh
so i have the 4 " rc long arm lift and have a question. Has any one had a problem with the front upper control arm hitting the front brake line. It looks like its gonna get pinched against the frame by the upper control arms right where it mounts to the lower control arm.
I haven't had a chance t take it out because 4 front bump stop bolt heads broke and the drivers side rear bump stop broke. The rust sucks.
And has anyone had problems with front springs falling out?
tommyooooooh is offline
post #204 of 504 Old 02-07-2013, 03:53 PM
PhantomWJ
2003 WJ
Reroute it in between the Y....upper and lower arms.
PhantomWJ is offline
post #205 of 504 Old 02-07-2013, 04:04 PM
tommyooooooh
between Y wouldn't that cause it to get ripped out by the arm during down travel? or am i misunderstanding what you mean.
post #206 of 504 Old 02-07-2013, 04:15 PM
PhantomWJ
2003 WJ
In between the lower long arm and short upper arm...those two are fixed points....they move together.
post #207 of 504 Old 02-07-2013, 04:25 PM
tommyooooooh
itll just pop out unless its zip tied. It looks like the mount on the lower arm where the upper arm connects will hit the brake line right at the bracket where the rubber line meets the hardline. page 3 and 4 have pictures of the control arm and brake line bracket. maybe I'm just over thinking it but doesn't look to good for the brake line to me.
post #208 of 504 Old 02-07-2013, 06:35 PM
aleet25
2003 WJ
Got my kit in the mail today and had a local shop put all the joints together for me. Install begins tomorrow afternoon! T-minus 20 hrs!!
aleet25 is offline
post #209 of 504 Old 02-08-2013, 05:13 AM
aleet25
2003 WJ
Quick question guys. What were y'all's lengths on your control arms? Did you go by RC's instructions?
aleet25 is offline
post #210 of 504 Old 02-08-2013, 08:59 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
I set mine according to the instructions. The only ones I needed to change during alignment were the front uppers. Everything else ended up just about perfect.
~James
ezflip is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
