Guinea pig new RC Long Arm kit? - Page 13 - JeepForum.com
post #181 of 504 Old 02-01-2013, 03:44 PM
kaktus
So let me get this straight.... If I get this lift kit and I decide its not big enough for me I can just put in 6" coils or I could even add BB on top of the RC springs and it will work? I'm sure adding the coils is a better route if your out wheel'N. I just want to make sure if I drop $1500 I won't be stuck with a 4" lift.
kaktus is offline
post #182 of 504 Old 02-01-2013, 08:38 PM
aleet25
2003 WJ
I ordered mine this morning. I can't wait for it to get here Weds so I can get it installed on Sat!
aleet25 is offline
post #183 of 504 Old 02-01-2013, 11:57 PM
Timbo24
I think you would need new shocks as well.
Timbo24 is offline
post #184 of 504 Old 02-02-2013, 12:46 AM
kaktus
I would need new shocks if I put 6" springs in.. Can anyone confirm this? What are the shocks that come with the RC 4" lifted rated for? Only a max of a 4" lift? If I did a BB I would sacrifice not being able to flex without the springs coming out but on the plus side I would not need new shocks. Hrmmm.....
kaktus is offline
post #185 of 504 Old 02-02-2013, 06:37 AM
texlurch
You'll need new shocks. The RC ones are for 4.5 lift, and if you top them out you'll blow them.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #186 of 504 Old 02-02-2013, 06:43 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Shocks dont exactly have a wide range they can be run at. The RC shocks are designed for their 4" lift. Any deviation from that will destroy them fairly quickly. You will most definitely need shocks designed for a 6" lift if you go with 6" coils. Everything else in the RC will work just fine after being properly adjusted.
~James
ezflip is online now
post #187 of 504 Old 02-02-2013, 11:34 AM
kaktus
Okay any input is welcome. Instead of buying the RC 4" long arm suspension kit. I'm just going to buy the RC 4" long arm upgrade kit. Then add 6" inch coils along with bilstien 5100 shocks made for a 6" lift along with a adjustable track bar? Will I need anything else? The upgrade kits looks complete just its missing shocks, springs, and track bar. Is this correct?
http://www.roughcountry.com/jeep-wj-...rm-upgrade.php
Thanks everyone
kaktus is offline
post #188 of 504 Old 02-02-2013, 04:25 PM
Roger005
Thanks everyone
No rear shock relocation brackets. I am pretty sure that's it. You wanting to run 33's?
Roger005 is offline
post #189 of 504 Old 02-02-2013, 11:45 PM
kaktus
Yes I want to run 33's.
kaktus is offline
post #190 of 504 Old 02-03-2013, 01:00 PM
precisioninstal
Don't forget about brake lines.
precisioninstal is offline
post #191 of 504 Old 02-03-2013, 01:56 PM
PhantomWJ
2003 WJ
rear shock relocation is not require if you are running aftermarket wheels with less back spacing...
extended brake lines are not required, only recomended...
you will want longer front and rear sway bar links...those for the 4" will do but the anti-sway bars wont be at their optimal angle...
you will need longer shocks to complement your 6" lift...
You will want longer bump stops so you wont tear apart your fenders every time your wheel gets stuffed, that is if you disconnect.
Front and rear driveshafts...
OH, BY THE WAY...did you read this....http://www.jeepforum.com/forum/attac...iftchartv2.jpg
PhantomWJ is offline
post #192 of 504 Old 02-04-2013, 12:36 PM
aleet25
2003 WJ
Just talked to Darrell over at RC and he says that the 2.2 shocks ARE compatible with 6" of lift.
aleet25 is offline
post #193 of 504 Old 02-04-2013, 01:54 PM
PhantomWJ
2003 WJ
I had those 2.2 on my prevoius 4" lift, they are not long enough.
post #194 of 504 Old 02-04-2013, 08:42 PM
Roger005
Do you happen to know what you are running for alignment specs? I am doing the same kit but I am going to put 3/4" spacers up front as well. Do you know what your caster is set at by chance? Thank you.
Roger005 is offline
post #195 of 504 Old 02-04-2013, 08:47 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Darrell is kind of an idiot. Ive talked to him a few times and now I ask for someone else when I call haha.
My caster is set at 4.1 right now, but im going to raise it to 5 - 5.5. Steering is just a little bit sloppy right now. Before I got my alignment right after install it was at like 9 and was super tight, just had lots of driveline vibes.
~James
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 02:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 12:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 06:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
