Guinea pig new RC Long Arm kit? - Page 10 - JeepForum.com
post #136 of 504 Old 01-12-2013, 08:27 PM
narnwv
narnwv's Avatar
Originally Posted by MWyatt View Post
Can someone explain the set up in the rear? Why is it the stock "short" a-arm with lower long arms? Doesnt the shorter a-arm limit the long arms on the bottom? Whats the point?
Thanks
It's adjustable on the axle end. The longer lowers will help ride/flex, and adjusibility will allow you to move the rear axle backwards. The adjustable upper will allow you to dial in the pinion angle properly.
Yes, to a point, it can/will limit flex compared to say, Clayton's 4-link setup, but it won't be too bad, as the body side of the arm is angled, better joints, and after adjusting, it will be longer.
~Aaron
narnwv is offline
post #137 of 504 Old 01-13-2013, 02:09 AM
MWyatt
Thanks for clearing that up
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline
post #138 of 504 Old 01-13-2013, 07:11 AM
texlurch
How is the height compared to the IROR or Clayton 4 inch kits? Did you get an actual 4 inches from the lift?
Also, on the rear sway bar.. rather than using the spacer blocks is there any interference leaving it alone, and using longer JKS discos?
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #139 of 504 Old 01-15-2013, 11:16 AM
Killallblue
Buying this lift today can't wait
Killallblue is online now
post #140 of 504 Old 01-16-2013, 12:19 PM
Roger005
Keep me posted please. I am highly considering it when it warms up. I have a stock 04 HO now. Let me know what you think of it.
Thanks
Roger005 is offline
post #141 of 504 Old 01-16-2013, 12:28 PM
Rhigondus
I have the 4 x series kit, I didn't go long arm cuz my wife said if I Ruin my rims she'll kill me. But to keep the 17' wheels and 33's from rubbing i went with a 4 inch lift my kit was 800 plus the stabilizer 130 def worth it the parts are alot more impressive than I thought they'd be Im happy with my choice
Rhigondus is offline
post #142 of 504 Old 01-16-2013, 06:44 PM
Roger005
Has anyone ever had to do any type of exhaust modification with this kit? I am about to drop some cash on a Magnaflow exhaust but I don't want to have it redone in the spring when I install this kit?
Thank you
Roger005 is offline
post #143 of 504 Old 01-16-2013, 11:52 PM
texlurch
Thank you
The only one you have to modify exhaust on is Claytons, due to the upper control arms. The RC kit uses the stock upper mounts.
texlurch is offline
post #144 of 504 Old 01-17-2013, 12:00 AM
PhantomWJ
2003 WJ
Originally Posted by oaklyjeep10 View Post
I'm running this kit w RC 4" and 2" bb. I'm wanting to put taller springs and trash the spacers, how do I know how much to adjust everything? And what springs would you guys recommend?
MrJ has some 6.5" coils in the classified along with the shocks too...
PhantomWJ is offline
post #145 of 504 Old 01-17-2013, 08:58 PM
Killallblue
post #146 of 504 Old 01-21-2013, 10:38 AM
soupy688
Wj
I just ordered my rc long arm kit. I am also upgrading my shocks to bilstein 5100's. My kit should be here this Wednesday. Those of you who have the kit. Do they specify on how to set and adjust the arms? I have never had to deal with adjustable arms. any input on this would be great. thank you
2012 Jeep JKU Call of duty MW3 serial # 1526/3500 Bone Stock
soupy688 is offline
post #147 of 504 Old 01-21-2013, 11:14 AM
adavis39
im sure they will come with "starting point settings"...if not contact RC and they will tell you. But those are only STARTING POINTS that should get you close to the correct specs....all WJs are slightly different and not everyone will have the exact same length arms....just mess around with it till you get it setup the best way FOR YOU
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #148 of 504 Old 01-21-2013, 11:17 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
http://roughcountry.com/install/908.pdf
You will also get a copy of the instructions in one of the boxes. The lengths given in the instructions will get you close enough to get it to an alignment rack to fine tune it to what you want.
~James
ezflip is offline
post #149 of 504 Old 01-21-2013, 12:53 PM
Timbo24
How much did it run ya? And where did you get it from? Thanks
Timbo24 is offline
post #150 of 504 Old 01-21-2013, 03:09 PM
soupy688
I ordered my kit from jeephut Very good people and easy to deal with. After reading the instructions im starting to think "what did I get myself into?" Ive lifted my jeep 2 different times but never had to deal with arms I have all of the tools needed for the install its just the long arms are making me nurvis. Those who have done this install please please please rate the difficulty and your experiences with the install.
soupy688 is offline
rc , rc longarm , rough country , rough country long arm
Best Long Arm kit for the $$$ 04dubjay WJ Grand Cherokee Forum 25 04-11-2012 03:43 PM
Rusty's long arms vs claytons long arms RKOTAREK WJ Grand Cherokee Forum 6 03-13-2012 01:12 PM
whats the difference between a normal long arm kit and a critical path long arm kit? ozgrand WJ Grand Cherokee Forum 13 01-02-2012 07:25 PM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-11-2011 12:57 AM
