growling noise on our 2003 WJ when making tight 90 degree turns ? - JeepForum.com
post #1 of 8 Old 11-27-2014, 06:38 PM Thread Starter
desert_sand
2003 WJ
Wj growling noise on our 2003 WJ when making tight 90 degree turns ?
just bought a sweet 2003 Overland. Runs fine in a straight line, or when making a gradual turn. When making a tight 90 degree turn, there is a loud growling noise. Is this related to the 4X4 ? What is the best way to check for possible causes ?
thanks
desert_sand is offline
post #2 of 8 Old 11-27-2014, 07:04 PM
PatriotBlue02WJ
Does it sound like its coming from a certain wheel, or from the diffs? 1st step would be to pop the diffs open and inspect.
PatriotBlue02WJ is offline
post #3 of 8 Old 11-27-2014, 07:40 PM
PowderHound
2003 WJ
It could be the front varilok axle doing its job and trying to lock up since one wheel is rotating more on sharp turns. Mine groans when doing a tight u turn; a light groan noise is normal. I'm not sure how loud yours is, but the varilocks do make noise.
PowderHound is offline
post #4 of 8 Old 11-27-2014, 08:35 PM
99SK04GTX
wjjeeps.com is your friend. On that Overland you have a transfer case, a 247, that takes a special fluid only; no ATF+4. You have varilocs and they need mopar friction modifier to reduce the squawk in tight turns
99SK04GTX is offline
post #5 of 8 Old 11-28-2014, 03:15 PM
Louisianaboy
Yep. U need more friction modifier.... With a fluid change
Louisianaboy is offline
post #6 of 8 Old 12-12-2014, 10:39 AM Thread Starter
desert_sand
2003 WJ
Wj Friction modifier is the solution !
Many thanks guys. Your advice was 100 % correct. After the dealer changed all the diff and trans case fluids - no more growling noise.( about $500. later )
Looks like the previous owner had taken it somewhere where they had put in the wrong fluid. Is the Jeep unique in needing this special fluid ? Would it be better to keep getting the dealer to do the 4 X 4 service, to ensure they use
the right stuff ? How often do these fluids need to be changed ?
post #7 of 8 Old 12-12-2014, 12:17 PM
dcorn
wjjeeps.com has answers to all your questions.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #8 of 8 Old 12-12-2014, 02:32 PM
Jeeples
Jeeples's Avatar
It's not necessarily the gear oil/fluid, as it's the additional friction modifier that's needed to prevent the Vari-lok/LSD's from binding during tight turns. As others have mentioned, you can read more about how the Vari-lok differentials function in you WJ by going to WJJeeps.com
That being said, $500 is a lot of money to spend on having two differentials serviced. I'm not aware of your mechanical ability or know-how, but a differential service can easily be done in your driveway with basic hand tools. Even if you had to buy a basic mechanic's tool set, you likely would have been under $200 in tools and fluids (depending on how crazy you wanted to get on your fluids).
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
