Ground Wire locations for WJ's - JeepForum.com
post #1 of 11 Old 09-19-2017, 03:15 AM Thread Starter
GhostJeepWJ
GhostJeepWJ's Avatar
Question Ground Wire locations for WJ's
While doing work on her this weekend, I found a ground wire that is unattached underneath. It's located back by the transmission and I believe it attaches to the bolt holding bracket for the exhaust. Noticed while removing the transfer skid plate. There is another one underneath near the rear of the engine if memory serves me correctly that is also just"hanging" out. So after finding this one over the weekend, I want to go over all my ground wires and clean/replacee/attach them all. I know there is one connected to the firewall. But where are the others and how are they attached?....
Thanks in advance for dropping some knowledge on me!....lol
If you want to achieve greatness, stop asking for permission!!
2002 Grand Cherokee Overland 4.7 HO
2" IRO Spring Lift w/Bilstein 5100s 245/75/R17 Goodyear Armour Shield
GhostJeepWJ is online now
post #2 of 11 Old 09-19-2017, 04:28 PM
RoysJeep
Junior Member
RoysJeep's Avatar
I was gonna mention the one on the firewall, but you already mentioned it lol
I'm surprised wjjeeps doesn't have any info on this
2004 WJ Laredo, 4.0, 197,xxx miles and counting, 3:55 gears, D30/D35c. Stock for now
RoysJeep is offline
post #3 of 11 Old 09-19-2017, 06:41 PM Thread Starter
GhostJeepWJ
Yea I looked and didn't seen anything on there.
I think that one I saw that was broken runs from a mounting bolt for the crossmember to a bolt holding the exhaust hanger. Just several inches away.
post #4 of 11 Old 09-19-2017, 07:35 PM Thread Starter
GhostJeepWJ
After @WiLieR dropped some knowledge on me....(thanks btw bud)
There looks to be 3....
One that wired with the radio antenna
two - pass side of the engine from the firewall to stud (differs between 4.0 has a single strap and 4.7 has a "Y" strap)
three - from the body (exhaust hanger mount) to transmission or transfer case
post #5 of 11 Old 09-24-2017, 09:49 AM
gtg413i
2003 WJ
Do you have more details of the radio antennae ground location?
Brian's Black Betty Build:
gtg413i is offline
post #6 of 11 Old 09-24-2017, 01:19 PM
99SK04GTX
This thread has some pretty good info on grounds: http://www.jeepforum.com/forum/f310/...ation-4133977/
99SK04GTX is online now
post #7 of 11 Old 09-24-2017, 05:01 PM
gtg413i
2003 WJ
Yup. I didn't see the antennae ground location in the thread though. I'm chasing engine noise coming through the radio.
gtg413i is offline
post #8 of 11 Old 09-26-2017, 05:14 AM
99SK04GTX
I believe I have read that the ground that attaches to the exhaust system clamp is the source of radio noise when it is broken or making poor contact.
post #9 of 11 Old 09-26-2017, 10:35 AM
Double E
Double E's Avatar
^ That's correct. Search on some old posts on that. It's been discussed before. Why they put such garbage braided wiring in there only to crumble is beyond me.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #10 of 11 Old 09-26-2017, 03:40 PM
gtg413i
2003 WJ
I've replaced that one with some solid wire and a new braid and tried to clean up the rust. I'll give it another shot, but I think my interference noise is from the engine, since I had a rebuilt one put in, who knows what electronics systems could be the culprit.
gtg413i is offline
post #11 of 11 Old 09-26-2017, 07:35 PM
wolf_7669
This article may help you track it down.
http://www.popularmechanics.com/cars...o/a84/1272491/
wolf_7669 is offline
