Grinding/rubbing noise from centre console - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Grinding/rubbing noise from centre console
We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-21-2015, 09:45 PM   #1
sdg3205
sdg3205's Avatar
When I hit the brakes with authority, or make a turn even at a crawl I often hear a soft grinding sound - picture a fan just barely hitting the shroud.
I thought maybe it was the blower motor coming loose, but the sound persists when i turn off the HVAC. I'll get a video of it. I really don't know how else to describe it.
sdg3205 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 06:53 AM   #2
seraph_rapture
I have the same sound, I suspect it's the shift cable rubbing on the driveshaft when braking, been meaning to climb down there and zip tie it up.
From 2.5/AX5, 30" Geolander, 2" BL
TO 4.0/AW4, 2.5 OME SOA, 5/8" boomerangs, 8.8 Aussie locked, D30 CAD eliminated, 35" Radial Rover, JCR 4x4 front and rear bumpers, ENGO 9000, Volvo e-fan, TJ rock rails, etc etc.
seraph_rapture is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 10:06 AM   #3
sdg3205
sdg3205's Avatar
I'll check that out.
Unread Yesterday, 06:39 PM   #4
sdg3205
sdg3205's Avatar
Made a video folks. You can hear it a bunch of times. Some change/coins move around a couple times too, but are audibly different.
EDIT - good instance at 36 seconds and 43 seconds.
Here
Unread Yesterday, 10:21 PM   #5
sdg3205
sdg3205's Avatar
Found this. Fir tree holding the transfer case cable had come off. I could see some rubbing on the plastic. It was certainly rubbing on the drive shaft, though I'm not sure this was the sound. I can't see how braking would cause it to move leftward into the drive shaft.
At any rate, back in place with some zip ties too.
Unread Yesterday, 10:52 PM   #6
Krooser
I had the same grinding and rubbing going on a while back… told my GF to get off the console and sit in her seat...
Krooser is offline   Reply With Quote Quick reply to this message
