I'm usually in the zj section but this is for a friend. He has a 02 wj overland.
When you're done making a turn and start going straight you feel a (sort of) grinding noise/feeling but only for a few seconds. Also sometimes when u come a stop, and then start accelerating you will feel it for a few seconds.
It's hard to explain its not really a grinding feeling, more of a wobble feeling from somewhere in the front diff or drive shaft I think.
I did a visual inspection and that only thing I found was that I was able to turn his front driveshaft about a half inch when it's parked.
Is that normal? I checked my zj and it doesn't do that.
Both our grands have the 249 TC if that helps anything
Any ideas?
