Grinding from left rear wheel? - JeepForum.com
post #1 of 14 Old 04-06-2013, 12:11 AM Thread Starter
imdave
Driving home, I started hearing a loud grinding noise coming from my left rear wheel. Stopped and saw fluid. I pulled it into a parking spot as the ABS light came on and the brake pedal dropped (not all the way to the floor). Any one have this problem? Any ideas of what it could be? I'm afraid it's the axle seal and even more afraid that I will need to change out the axle shaft (did it once before on a different car, and it was a nightmare).
imdave is offline
post #2 of 14 Old 04-06-2013, 12:22 AM
cykaaro
Are you sure it's not the caliper is gone? Can't see how the ABS would be effected by the axle leaking. Had mine leaking on the one side but suddenly stopped for some reason, but has a bit of play in the bearing so will need to be done soon. Never effected the ABS or breaks.
My one caliper gave out last week. Didn't hear any noise unless I was turning, but on closer inspection could smell a metal on metal burning smell. Add to that your pedal dropped as well, possibly the caliper is toast, and may have leaked fluid out.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 14 Old 04-06-2013, 05:11 AM Thread Starter
imdave
Removed the caliper, and capped it. Drove it to a mechanic. On the way there the grinding noise came back. I need to replace the bearing, seal, and axle. Mechanic said that the sensor will 'freak out' if something is going wrong around it. If the brake has a problem, I'll post more, but for now I need an axle. Any tips on inexpensive ones? I'm tight for money.
imdave is offline
post #4 of 14 Old 04-06-2013, 05:36 AM
car5car
2002 M-38
You need to buy special "repair" bearing
01 XJ 2wd 4.0
car5car is offline
post #5 of 14 Old 04-06-2013, 07:41 AM
99WJ01TJ
I think your ABS was just doing it's job. When i go off roading I get on pretty gnarly trails that have rediculous declines & i've noticed that on descents if 1 front wheel is on a hard surface & the other hits loose dirt & slides the ABS light comes on my pedal gets soft. It does this so that it can make sure that both wheels on that axle are going the same speed while the brakes are applied(thats why all 4 wheels have speed sensors) keeping the vehicle from loosing control under braking. I think your light came on because you lost a bunch of oil from your bearing & when the brakes were applied it wasn't able to slow that wheel down as much as the other wheel due to the pads slipping on the oil covered rotor.
99WJ01TJ is offline
post #6 of 14 Old 04-06-2013, 03:06 PM
ujoint
Your bearing went bad and the axle pulled out causing it to push your caliper piston back in. That's why you had to brake go down. the axle pulling out moved the tone wheel for the sensor to that is your abs light. That axle should have a seal, bearing and lock ring all pressed on together. the bearing does not ride on the axle itself it rides on a race and has a cup that goes in the axle tube. unless you tore up the axle shaft driving it hanging out it should be ok.
ujoint is offline
post #7 of 14 Old 04-09-2013, 12:59 AM
airborne75
Where is the best place to buy bearings and seals?
airborne75 is offline
post #8 of 14 Old 07-05-2013, 03:05 PM Thread Starter
imdave
I would go to Factorycryslerparts.com. That's where I've gotten all the parts, and they have good Illustrated Parts Breakdowns.
imdave is offline
post #9 of 14 Old 07-05-2013, 03:10 PM Thread Starter
imdave
Sorry it took so long to post the follow up, but here's a link to pics when I took it apart. Got it up and running, and yes it was the left rear bearing that fell apart.
http://www.facebook.com/david.peters...1205057&type=3
imdave is offline
post #10 of 14 Old 07-05-2013, 03:14 PM Thread Starter
imdave
Thanks for the info! I honestly thought that the axle did ride on the bearing. I'm mechanically inclined but I can always use learning more!
imdave is offline
post #11 of 14 Old 07-05-2013, 07:13 PM
cykaaro
Glad you got it fixed ok. When mine was starting to go, was actually a different problem was happening, but noticed that the caliper spring was riding on the rotor and didn't look straight. sure enough i t was in bad shape. Think the angle though was enough to not allow it to leak, which is why the leaking stopped. better yet where I had it done, they told me it was changed out before and wasn't done properly. All good so far since getting it done.
cykaaro is offline
post #12 of 14 Old 07-07-2013, 03:45 AM Thread Starter
imdave
lol so I finally got a proper torque wrench in the mail. Go to apply proper torque value to the retaining plate, and snap. Awaiting more parts lol
imdave is offline
post #13 of 14 Old 07-07-2013, 05:13 AM
cykaaro
Well, that's not good.
cykaaro is offline
post #14 of 14 Old 07-07-2013, 07:20 AM
doityourselfMM
doityourselfMM's Avatar
How much torque were you applying?
doityourselfMM is offline
