Grand Cherokee - Tail Lights Not Working - JeepForum.com
post #1 of 6 Old 01-30-2012, 04:51 PM Thread Starter
dooley5
So I started with no tail lights and 1 missing brake light.
All other lights (interior, front, turn signals) worked fine. I changed bulbs - still no luck. Changed fuses - no luck. Read a prior post about the adjusting the chrome pieces on the metal assembly.. tried it and now the brake lights both work but not the tail lights.
About an hour after brake light fixed, the right turn signal started blinking fast.
Any ideas what can cause the faulty tail lights and quick turn signal?
dooley5 is offline
post #2 of 6 Old 01-31-2012, 12:58 AM
85IrocZ-28
The sockets and tail lamp assemblies have issues. After cleaning connections and fixing mine several times, I finally bought LED lights on Ebay.
Before you buy new housings and sockets though, I would pull out a voltmeter, unplug the wiring harness, and start testing for power at the harness. If you are getting power back there for tail lights, brake lights, turn signals, you have a good ground...time to replace the housings.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #3 of 6 Old 01-31-2012, 03:50 PM
Cowboyup94
agreed. the sockets suck. and are expensive to buy new. I went to the salvage yard to replace mine.
Cowboyup94 is offline
post #4 of 6 Old 01-31-2012, 04:23 PM
mycreativename
I was having a similar issue, and after testing enough that I was satisfied the housing itself was not the culprit, I ordered these. (http://www.amazon.com/Dorman-923-034-Tail-Lamp-Socket/dp/B000TYSBYY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1328048444&sr=8-1-fkmr0). At ~5 bucks a pop, I bought 6 replacements just so I don't have to deal with the BS anymore. I had gotten pulled over 3 times for having a tail light out, 2 of those times the cop let me get out and show him how to fix it quickly, (I had gotten it down to a <3 minute process).
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #5 of 6 Old 01-31-2012, 05:21 PM
MiCrOz
I had this problem also, wound up going with LED's.
2000 WJ 4.7 (work in progress)
Offroad: 6.5" IRO long arm high clearance, Bilstein 5125 - 35x12.5 KM2's - 242 swap - 4.56 w/ stock Varilok
Onroad: Spyder Full LED tails, Projector Heads w/ DDM 6k slim HID, Addco rear sway
MiCrOz is offline
post #6 of 6 Old 01-31-2012, 07:04 PM
Cowboyup94
Originally Posted by mycreativename View Post
I was having a similar issue, and after testing enough that I was satisfied the housing itself was not the culprit, I ordered these. (http://www.amazon.com/Dorman-923-034...4&sr=8-1-fkmr0). At ~5 bucks a pop, I bought 6 replacements just so I don't have to deal with the BS anymore. I had gotten pulled over 3 times for having a tail light out, 2 of those times the cop let me get out and show him how to fix it quickly, (I had gotten it down to a <3 minute process).
Thats a dang good price!!! I prolly almost paid that for a used one! Thanks for showing that!!
LED Tail Lights for 2007 Grand Cherokee Laredo discovery1979 WK Grand Cherokee & XK Commander Forum 12 10-05-2014 04:35 AM
2005 Grand Cherokee lights on heater control unit and stereo not working-both operate ElliottF WK Grand Cherokee & XK Commander Forum 7 12-13-2011 03:15 PM
1995 Jeep Grand Cherokee Limited interior door lights not working? themuzz ZJ Grand Cherokee Forum 8 06-29-2011 05:30 PM
Jeep Grand cherokee tail lights sanca19 Grand Cherokee General Discussion 1 09-09-2010 09:32 PM
1996 Grand Cherokee Marker Lights not working twisted_ed ZJ Grand Cherokee Forum 1 04-30-2009 12:25 PM
