Grand Cherokee Noise - JeepForum.com
post #1 of 3 Old 05-05-2013, 12:25 PM Thread Starter
joboco
I'm not sure if I am posting this in the correct place.
I have a 2002 Grand Cherokee 2.7crd. Recently I have had a rumbling noise coming from the front end that as got worse over the last 5,000 miles. This noise as now developed and is occurring at all speeds, in a straight line and in right hand bends, but disappears in left hand bends. There is also a vibration that has developed through the steering wheel, and can also be felt though the floor. I have jacked the front end up, and rotated a wheel. It moves about an inch before the other wheel moves. This is the same with both wheels, but there is a loud clunking noise from the diff when the slack is taken up. The front prop shaft only rotates about 2 millimeters before the wheels turn. Wheel bearing seam good, no movement when I waggle the road wheel top and bottom. The diff oil is the correct level and new, about 3 years, 30,000 miles back. Also the cv joint rubbers are looking good.
Could anyone offer any suggestions as to what this problem could be.
Thanks for reading.
joboco is offline
post #2 of 3 Old 05-06-2013, 01:50 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
diff oil at 30k is actually past the need for change.
it sounds like you've got gear problems, i'd open up the diff and have a look. test for side play and back lash on the ring gear.
ratmonkey is offline
post #3 of 3 Old 05-06-2013, 02:24 PM Thread Starter
joboco
I did think about that ratmonkey, but the problem is not there in a left hand bend, is that normal with a ring gear fault? The steering is also wondering quite a lot just now, and getting worse.
joboco is offline
