Got the new lift on yesterday! ...now dreaded rear shock noises!!! HELP! - JeepForum.com
post #1 of 7 Old 05-06-2012, 06:35 AM Thread Starter
SirWilliam
Thumbs down Got the new lift on yesterday! ...now dreaded rear shock noises!!! HELP!
Well, we finally put on the 4.5" lift that I've had sitting in boxes at my office for like 4 months. We didn't run into to many issues other than the danged bolts in the top of the rear diff....they're a pain in the tail! It seems to drive pretty well considering it's not been aligned yet, but I'm getting both squeaks and some knocking from the rear shocks. I know this has been addressed, but in tons of different threads.
The lift is from Rusty's and it's running their shocks. I will upgrade to Bilsteins when I can, but for now, I just need to get it to be quiet so my wife won't kill me! Ideas?
2004 WJ Overland - 4.5" Lift - 2012 JK Sahara 18" 7-Spoke Polished Wheels with stock JK Bridgestones
SirWilliam is offline
post #2 of 7 Old 05-06-2012, 07:09 AM
D0dgeRam1500
My lift is doing that too. I am running Teraflex springs and Bilstein shocks. My old OME HD springs and my old Bilstein shocks didn't squeak.
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #3 of 7 Old 05-06-2012, 07:39 AM
Lysdexic
Which kit? If it's the short arm lift you're probably stuck with it. My short arm front end was mad noisy, converting to long arm made a huge difference. Now I have to save up for the rear. Should have done long arm from the gate, whenever I cheap out it bites me in the ***.
If it's easy to get to it's probably not worth seeing.
Lysdexic is offline
post #4 of 7 Old 05-06-2012, 07:42 AM
qbny94
same man i installed my 2 inch BDS coil lift with the BDS shocks and now when my gear is in drive i have a KLUNK noise
qbny94 is offline
post #5 of 7 Old 05-06-2012, 07:43 AM Thread Starter
SirWilliam
I'm about 85-90% sure it's the rear shocks. I know that's where the squeaking is coming from, but not sure on the clunk yet.
post #6 of 7 Old 05-06-2012, 11:00 AM
mycreativename
I thought it had something to do with the top rear bolt not being tight enough in the hole or something of that nature. Sorry I can't be of more help but I'm sure one of those members that has fixed it will chime in soon.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #7 of 7 Old 05-06-2012, 04:15 PM
aleet25
2003 WJ
I had a similar thing happen to me. It turns out my bolts hiding the shocks on weren't tight enough. Tighten the hell out of them.
aleet25 is offline
Got the dreaded "Rear Rattle" Shinner WJ Grand Cherokee Forum 24 11-13-2013 11:46 AM
rear shock orientation? devinci WJ Grand Cherokee Forum 7 01-08-2012 06:13 PM
The dreaded dash removal.... Jeep_ablaze WJ Grand Cherokee Forum 21 11-27-2011 10:27 AM
The dreaded P0740 solved Maugli WJ Grand Cherokee Forum 0 10-15-2010 08:32 PM
I put an AddCo rear swaybar on my WJ yesterday dlwilson42 WJ Grand Cherokee Forum 14 05-04-2010 07:36 PM
