The good and the bad - JeepForum.com
post #1 of 6 Old 09-18-2010, 03:53 AM Thread Starter
99JeepGC47
2008 KK Liberty
Wj The good and the bad
Well. I got my new 4.7 engine running, and I fixed the problem I had with the leaking transmission cooler. I will get pictures when I can find my camera. I havfe 2 codes, P10123, and P0113, both i think happened when I was taking the plug off the sensor whole it was running but I am not sure.
My biggest problem though is I start it up and it shuts right off it will run if I keep my foot on the accelerator. I don't have the first clue were to look. I have check every conection, those are the only codes, I also put on a new fuel filter. I will start looking and playing around with it in a few hours.
99JeepGC47 is offline
post #2 of 6 Old 09-18-2010, 05:33 AM
creepingdeath94
How much have you run it so far? Maybe it needs a bit more time to run and set itself up/learn IAC counts? Is the IAC new/cleaned? Any vacuum leaks...all it might take is one small hose off or broken somewhere for this to happen.
creepingdeath94 is offline
post #3 of 6 Old 09-18-2010, 08:22 AM
Mr_Grumpy
Id disco the battery and clear the codes so you know for sure.
When the gas pedal is floored its, afaik, opening the butterfly and letting more air in. So maybe theres a problem there.Someone a lot better than i at these things will be along soon
Mr_Grumpy is offline
post #4 of 6 Old 09-18-2010, 09:07 AM Thread Starter
99JeepGC47
2008 KK Liberty
I am getting ready to go out and check all the vacum lines again. The IAC is the same one that has always be on the it, I did clean it though. I had had it running the day before it started doing this. I ran it for about 10-15 minutes, but I had a leak at the transmission cooler. I got some fresh gas, and some Heet to take out any water that may be in the tank. I will see what I find.
post #5 of 6 Old 09-18-2010, 10:25 AM Thread Starter
99JeepGC47
2008 KK Liberty
It is alive!!!!!!!!!!!!!! I don't know what I hit or did. I put in some Heet, and a little gas. I didn't even paly with the vacume lines. It is running now, I am going to take it around the block to see how everything feels. Thanks everyone for your help!
post #6 of 6 Old 09-18-2010, 10:34 AM
compcrasher86
It may have just figured out the IAC combinations but do not go too far until you deem it reliable. It is probably was or may still be the IAC. Nevertheless, good luck and enjoy the 4.7!
Matt
compcrasher86 is offline
Fedex was good to me today White2000WJ WJ Grand Cherokee Forum 7 09-09-2010 10:10 PM
Hello! it is good to be back and HELP! Beetlescott WJ Grand Cherokee Forum 9 04-05-2010 08:32 AM
Removed carpet for good QuadraTokn WJ Grand Cherokee Forum 20 03-21-2010 11:30 PM
Good Deal for an 02 GC Limited? rsteps WJ Grand Cherokee Forum 5 08-10-2007 10:23 AM
Good place for CB? froggo27 WJ Grand Cherokee Forum 29 07-26-2007 05:39 AM
