gears 10/11 27 or 56 - Stumped? - JeepForum.com
post #1 of 19 Old 05-13-2013, 06:14 AM Thread Starter
lance-tek
Wj gears 10/11 27 or 56 - Stumped?
I am trying to learn about the ring and pinion gears in an axle diff.
What I am really trying to figure out is what I should put in my WJ axles. I can't find a Dana 30 4:27 so, I think it's out of the running.
I am swapping my D35 for a D44a (and buying armor for it) and also regearing it to run 315-70-17s which will need at least a 4:10 on my WJ but maybe the 4:56 would be better for crawling and worse for the Highway?
What is the minute difference between the 4:10 and the 4:11 gears? Is it just the manufacturer spec or does it truly have an impact?
Thanks,
-lance
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline
post #2 of 19 Old 05-13-2013, 06:31 AM
Siva283
Thanks,
-lance
There is not enough of a difference between 4.10 & 4.56 to justify it. You will not notice it. Go for 4.10 you will be happy with that.
The difference between 4.10 & 4.11 has to do with the size of the ring gear. The front dif is slightly smaller than the rear. A lot of vehicles come from the factory with 4.10 in the front and 4.11 in the rear. It won't cause any issues. It is only a 1 percent difference. You are safe as high as a 5 percent difference.
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #3 of 19 Old 05-13-2013, 07:34 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
That tire is technically a 35. 4.10's will definitely not cut it in a 4.0 wj.
You want 4.88's.
ratmonkey is offline
post #4 of 19 Old 05-13-2013, 07:43 AM
veiri86
2003 WJ
You want 4.88's.
X2
And when you buy the 4.10, few weeks later, you would wish if you bought the 4.56, so go right away to 4.56 or 4.88
veiri86 is offline
post #5 of 19 Old 05-13-2013, 08:05 AM
Siva283
You want 4.88's.
My Bad I thought that worked out to a 33 inch tire. I also keep forgetting how my heavier my 01 WJ is than my YJ.
Siva283 is offline
post #6 of 19 Old 05-13-2013, 08:45 AM
USFORCES
I'm running 285/ 33 inch tires, Just waiting on 4.56 gears they should be be here any day
Talk to Kolak, He sells the nitro gears. "They are the highest quality forgings on the market the D44A sets are properly drilled for the 7/16" ring gear bolts used on the later WJs. They are the only ones that have 7/16" holes. Everybody else makes you use a funky adapter."
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #7 of 19 Old 05-13-2013, 08:49 AM Thread Starter
lance-tek
OK... now its between 4:56 and 4:88. At least I was able to rule out the 4:11
post #8 of 19 Old 05-13-2013, 09:22 AM
veiri86
2003 WJ
I was on the same ship for long time till last week, then I went for 4.56, ordered the nitro ones, as almost everybody recommends them if you are planning to run 33
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #9 of 19 Old 05-13-2013, 09:37 AM
Siva283
If you go 4.88 it will give you a little room to grow
Siva283 is offline
post #10 of 19 Old 05-13-2013, 10:16 AM
texlurch
Keep in mind on the D30, 4:56 and 4:88 have tiny pinions. That will be your weak point.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #11 of 19 Old 05-13-2013, 10:34 AM Thread Starter
lance-tek
I'd love to swap the front but, I am learning as I go and I don't know how to modify anything to fit onto the WJ. I only have my garage to work in too (I have a HOA in my sub division too). If anyone is interested in helping me learn I'll gladly get better axles :-)
post #12 of 19 Old 05-13-2013, 10:42 AM
skain8
skain8's Avatar
The small pinion will be the least of his problems.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #13 of 19 Old 05-13-2013, 10:53 AM
texlurch
true, true.
texlurch is offline
post #14 of 19 Old 05-13-2013, 10:57 AM Thread Starter
lance-tek
Can you elaborate on this statement for me? I'm pretty new to suspension/ drivetrains... ignorance is not bliss in this situation
post #15 of 19 Old 05-13-2013, 11:03 AM
texlurch
Stock axle'd D30's are "ok" up to a 32 in tire or so... for the average wheeler
Anything above that, and you really need to look at better axles, sleeves or trusses
Many people are running the stocker on 33/35 tires, and getting away with the occasional snapped CV..
You just have to be real, real easy on the skinny pedal.
texlurch is offline
