gauges all dead, lights all on - Page 2 - JeepForum.com
post #16 of 25 Old 10-21-2011, 03:09 PM
hpalmatier
2000 Jeep grand cherokee electrical problems
i am encountering the same electrical problems that a lot of other jeep owners are encountering. gauges going haywire, all my warning lights on, windows only working when the car is in the on position, but not once it starts up..command center is down. none of the buttons on my steering wheel work, and my ac and heat when on and in the vent position will blow through the defrosters and the vents and will switch back and forth. we have put thousands into this and still havent found an answer anywhere. put a new battery in, cleaned terminals, changed the ignition switch. we are getting a p1686 code. if anyone has a resolution, please let us know. the dealer couldnt even figure this problem out. help?!?!
hpalmatier is offline
post #17 of 25 Old 10-21-2011, 04:44 PM
little_Jeep
Have you been looking for a bad ground?
Search for your P11686 code, then compare what has been done to your Jeep to what has fixed other Jeeps......
Here is just one such thread that I found,
http://www.jeepsunlimited.com/forums...d.php?t=462082
little_Jeep is offline
post #18 of 25 Old 11-06-2011, 06:33 AM
notlegend
Update:
Replaced instrument panel, worked for a month;
Replaced power windows control, worked for a month;
Then the problem came back again, still no codes read from ECU, was told to replace clockspring, PCM etc.
I sold it.
notlegend is offline
post #19 of 25 Old 01-02-2012, 10:14 AM
p3dr0jeep
My gauges all die ... Everything works great in the cluster exept the gauges ... Please help
p3dr0jeep is offline
post #20 of 25 Old 01-02-2012, 10:34 AM
Rocklobster
Check the wires in the front door boots for damage, and as said the battery,connections,and grounds.
Rocklobster is offline
post #21 of 25 Old 01-02-2012, 06:07 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I am not saying this is the problem with any of these Jeeps, but on mine the main wire harness from the fuse box in the engine compartment goes through the firewall to a junction block behind the passengers side kick panel. There are 2 big connectors, approx 50 pins, on the junction block and the harness from the fuse box is the top connector. Well some how mine got all corroded and shorted out various wires causing all sorts of problems. Just something for everyone to check.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #22 of 25 Old 05-11-2012, 10:59 AM
radryan505
I had a lot of these same problems when up in the mountains and had to get my father in law to tow me home. He said it was something with the relays and the fuzes under the hood. All the mud puddles i go threw have got everything all dirty and lose. So today I am check it all out. We havent found the exact problem yet but... If this helps anyone. But my car keeps dying. My gauges will be going crazy as I drive then out of left field the car will die. We are thinking there is an open in the wiring that is happening when I hit bumps and such.
Chrome wont get you home! Better black it out if you wanna see your baby tonight.
Fetal Panic Ink---- Custom Shirts and Vinyl Decals----Fetalpanicink.com or Facebook Fetal Panic Ink.
radryan505 is offline
post #23 of 25 Old 09-13-2012, 05:26 PM
Dysan
I am having these same issues, but have noticed that if I put the key to the On position with the driver door closed and I roll the window down, I don't have the issue. I am hoping I have pin pointed the area where the possible short is. Will update when I finally have time to actually tear into the driver's door and kick panel. Will probably replace the bad front speakers while I am in there too.
Dysan is offline
post #24 of 25 Old 01-12-2013, 08:37 PM
zeltech
2012 - Jan.
I had this exact issue on a Jeep 2003 Grand Cherokee.
"- Gauges do not work, go to zero
- Odometer does not count mileage
- All warning lights are lit up
- No AC
- No Electric Windows
- Never Stalled the engine"
Headlights work fine,blinkers work fine.
I can tell you this.
I did nothing,but only clean out my battery terminals,because i had seen some corrosion going on.
Battery was only a year old.
After cleaning that, everything worked like a charm
No more further issues.
Definitely, on jeeps, Battery terminals need to be cleaned all the time for less issues to occur.
Always check that first when something electronic fails.
Zel
zeltech is offline
post #25 of 25 Old 11-08-2013, 05:06 PM
wikkid237
2012 WK
lllll
wikkid237 is offline
WJ Grand Cherokee Gauges cluster dead not working plus airbag light? apribby WJ Grand Cherokee Forum 16 06-07-2016 11:07 AM
Gauges don't work PaXJ WJ Grand Cherokee Forum 5 01-15-2011 02:35 PM
Need HELP!!! with head lights,Fog lights and tail lights JVL19 WJ Grand Cherokee Forum 9 08-16-2010 10:25 AM
No gauges kruiser52 WJ Grand Cherokee Forum 0 04-26-2010 06:58 PM
00 keeps flashing lights til dead BLACKRAM1 WJ Grand Cherokee Forum 3 01-31-2009 11:48 AM
