Gassy smell in my jeep - JeepForum.com
post #1 of 6 Old 04-09-2012, 07:50 PM Thread Starter
Lrw95
2010 JK Wrangler
I just got a '99 jeep grand cherokee. everythings good on it but whenever i fill it up past half tank, it starts getting a gassy smell. it really smells when i turn. any ideas on what it is or how to fix it? thanks.
Lrw95 is offline
post #2 of 6 Old 04-10-2012, 06:41 PM
lauderdalechad
2006 WK
Hole in the tank or filler neck, also check all lines coming from the tank for leaks.
And do you have a regular cherokee(xJ) or grand cherokee(wj)?? Your post and profile say 2 different things
2000 jeep wrangler sport: 31" BFG ATS, auto - wrecked
1997 jeep grand cherokee: stock - gf's zj
2000 Silverado 5.3l Z71- sold
2006 Overland HEMI QDII
lauderdalechad is offline
post #3 of 6 Old 04-10-2012, 07:46 PM
Sohcvtec1995
the fuel pump may have been changed and the rubber seal did not seat properly or is not even there
Sohcvtec1995 is offline
post #4 of 6 Old 04-17-2012, 10:37 AM Thread Starter
Lrw95
2010 JK Wrangler
Its a grand cherokee. and i took it in to get it fixed it was a number of things. like some high pressure line was spliced and the mechanic was shocked that it wasnt just spewing gas. thanks for the answers.
Lrw95 is offline
post #5 of 6 Old 04-17-2012, 10:52 AM
Cirruslydakota
When I bought mine I got the same thing after I filled up past 3/4. I dropped the tank and found the locking ring that holds down the fuel pump to be loose. Since I already bought a new locking ring and seal I just cleaned all the dirt out (and there will be dirt and rocks piled up in there.) and installed the new stuff after inspecting the pump and filter sock. Havent had a problem since then. Parts cost me around $25 so it wasnt too bad, but it is labor intensive especially if you have the factory hitch which forces you to take the bumper cover off to get to those last two bolts. Oh and if you replace the seal make sure to lube it up real good along with the nut threads with a soapy water solution so you dont tear the seal.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #6 of 6 Old 04-17-2012, 12:36 PM
adhdlacrosse16
2014 JK Wrangler
cant believe no one mentioned this yet but it could be driver induced. try less beans?
99' WJ... tank raise mesh grill homebrew cai
magnaflow 11226, banks header, bb sittin on 31s
adhdlacrosse16 is offline
1999 grand cherokee , jeep , problems
Ft Wayne Indiana Jeep Jam At O'Daniel with a JEEP STYLE Poker Run Jeepsruskaup JeepForum Announcements 0 10-05-2009 09:27 AM
Jeep Forum Jeep Clubs sickboy98tj JeepForum Announcements 2 04-05-2006 05:30 PM
