G Switch - JeepForum.com
post #1 of 14 Old 01-19-2012, 06:23 PM Thread Starter
MStaffin
G Switch
I got a code for my WJ. one is for the brake light on. It says G switch failure. Were and what is a G switch for the Wj. It is a 4.0 00. I have never heard of a G switch lol.
00 WJ Zone4in Clayton longarms and linked rearD30/D35 4.88s 33s locked
MStaffin is offline
post #2 of 14 Old 01-19-2012, 09:54 PM
bhicks
Maybe it's like the G-spot on a Jeep. Treat your Jeep really nice. Take her out for a nice drive and car wash and maybe she will let you know where that G-switch is.
____________________________________________
Past-SOLD2000 TJ, 4.0, 231HD,4.5" long armed lift, 4.56's, detroits, 35" KM1's
Past-SOLD 2000 XJ auto 242 4.0 6" Full traction long arm, Dana 44's, MTR Kevlar 35's, 4.88s, Detroits
Present- 2002 WJ Overland, 242HD(going in soon) 4.5" Teraflex/JKS lift, JCR Sliders, TAG bumpers, 33" Muds, 17" JK Moabs ( Future- 2012 JK Rubicon)
bhicks is offline
post #3 of 14 Old 01-19-2012, 10:00 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Only thing I can think of is the push plunger style switch on the brake pedal. Cant be 100% on that, but thats the only brake light switch I know of. Pretty simple to replace.
~James
ezflip is offline
post #4 of 14 Old 01-19-2012, 10:23 PM
eogg
You also have to drive her in in just the right position.
Constantly emptying every pocket
Colorado Jeep Club Member #1010
eogg is offline
post #5 of 14 Old 01-20-2012, 06:11 AM Thread Starter
MStaffin
To bad. I dont drive her..........
MStaffin is offline
post #6 of 14 Old 01-20-2012, 08:39 AM
rm2001wj
rm2001wj's Avatar
It's under the back seat. Maybe this diagram which shows the location of the G-switch connector will help.
rm2001wj is offline
post #7 of 14 Old 01-22-2012, 09:52 AM Thread Starter
MStaffin
Thanks. Pulled the G switch out. Hopefully napa has one. Sis sick so jeeps not leaving yet.
MStaffin is offline
post #8 of 14 Old 01-22-2012, 10:31 AM Thread Starter
MStaffin
Got the propername for it. Its called an ABS accelerator switch.
MStaffin is offline
post #9 of 14 Old 05-21-2013, 09:16 PM
jeep4venturing
1993 XJ Cherokee
is this switch on the inside under the carpet or outside above the axle?
Follow me on Facebook @jeep4venturing formore project details
jeep4venturing is offline
post #10 of 14 Old 05-21-2013, 09:36 PM
fsjmechanic
G probably means G-force. Many vehicles have one that acts as a fuel cut-off when it experiences high G's ( like 4 G's or so) which would indicate a crash. My old Ford Exploder had one......
fsjmechanic is offline
post #11 of 14 Old 05-22-2013, 08:59 AM
doityourselfMM
doityourselfMM's Avatar
Are you getting any other codes? I was getting G Switch and ABS Pump failure codes simultaneously. Intermittantly. I kept resetting the codes and they kept reappearing. I replaced the G Switch and the codes kept on coming. *#@*!
I ending up replacing the Controller Anitlock Brakes (CAB). Problem solved. $$$....
Hopefully, replacing your switch will help the 'old girl' out. Maybe a bottle of Ripple Wine will loosen her up.
doityourselfMM is offline
post #12 of 14 Old 05-22-2013, 12:11 PM Thread Starter
MStaffin
Well about 2 weeks ago the rad cracked and the trans mixed with. Took out trans. Jeeps on jacks. Its getting rubi axles and a 6" lift wich I got from jy. My gf will be driving it.
MStaffin is offline
post #13 of 14 Old 11-13-2014, 07:47 AM
moes
i have a 1999 jeep though u[ all these codes can some one help me n tell me whats wrong tps low brake fliud switch under volts g switch malfutcoin ecu interal mal f
pump malf speed sencor malf ?? anyone have a clue
moes is offline
post #14 of 14 Old 11-13-2014, 03:52 PM
gatorchin
Originally Posted by doityourselfMM
Are you getting any other codes? I was getting G Switch and ABS Pump failure codes simultaneously. Intermittantly. I kept resetting the codes and they kept reappearing. I replaced the G Switch and the codes kept on coming. *#@*! I ending up replacing the Controller Anitlock Brakes (CAB). Problem solved. $$$.... Hopefully, replacing your switch will help the 'old girl' out. Maybe a bottle of Ripple Wine will loosen her up.
I had g switch code along with a host of others related to the abs system..still trying to find time to try and fix the solder points on the module or get a new one if that fails.
00' Laredo w/4.7, 2.5/2" fat bobs coil spring lift, front 3/4" spacer, bilsteins 5100's from Kolak, rear addco w/greasable bushings, 245/16/75 treadwright wardens, 247>242 transfer case swap, all control arms replaced with aftermarket, and lots more $ into various parts
gatorchin is offline
What's this switch for? 4x4Jeep WJ Grand Cherokee Forum 8 01-10-2012 01:51 PM
4wd switch pjkatz04 WJ Grand Cherokee Forum 0 12-06-2011 05:11 AM
Is it the switch? TheGeek WJ Grand Cherokee Forum 8 05-13-2011 03:54 PM
oil sending switch tommybear67 WJ Grand Cherokee Forum 3 04-08-2010 07:42 AM
WJ switch locations 04WJny WJ Grand Cherokee Forum 21 04-07-2010 09:46 PM
