-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   G Switch (http://www.jeepforum.com/forum/f310/g-switch-1316791/)
MStaffin 01-19-2012 07:23 PM
G Switch
I got a code for my WJ. one is for the brake light on. It says G switch failure. Were and what is a G switch for the Wj. It is a 4.0 00. I have never heard of a G switch lol.
bhicks 01-19-2012 10:54 PM
Maybe it's like the G-spot on a Jeep. Treat your Jeep really nice. Take her out for a nice drive and car wash and maybe she will let you know where that G-switch is.
ezflip 01-19-2012 11:00 PM
Only thing I can think of is the push plunger style switch on the brake pedal. Cant be 100% on that, but thats the only brake light switch I know of. Pretty simple to replace.
eogg 01-19-2012 11:23 PM
You also have to drive her in in just the right position.
MStaffin 01-20-2012 07:11 AM
To bad. I dont drive her..........
rm2001wj 01-20-2012 09:39 AM
1 Attachment(s)
It's under the back seat. Maybe this diagram which shows the location of the G-switch connector will help.
MStaffin 01-22-2012 10:52 AM
Thanks. Pulled the G switch out. Hopefully napa has one. Sis sick so jeeps not leaving yet.
MStaffin 01-22-2012 11:31 AM
Got the propername for it. Its called an ABS accelerator switch.
jeep4venturing 05-21-2013 10:16 PM
is this switch on the inside under the carpet or outside above the axle?
fsjmechanic 05-21-2013 10:36 PM
G probably means G-force. Many vehicles have one that acts as a fuel cut-off when it experiences high G's ( like 4 G's or so) which would indicate a crash. My old Ford Exploder had one......
doityourselfMM 05-22-2013 09:59 AM
Are you getting any other codes? I was getting G Switch and ABS Pump failure codes simultaneously. Intermittantly. I kept resetting the codes and they kept reappearing. I replaced the G Switch and the codes kept on coming. *#@*!
I ending up replacing the Controller Anitlock Brakes (CAB). Problem solved. $$$....
Hopefully, replacing your switch will help the 'old girl' out. Maybe a bottle of Ripple Wine will loosen her up.
:D
MStaffin 05-22-2013 01:11 PM
Well about 2 weeks ago the rad cracked and the trans mixed with. Took out trans. Jeeps on jacks. Its getting rubi axles and a 6" lift wich I got from jy. My gf will be driving it.
moes 11-13-2014 08:47 AM
i have a 1999 jeep though u[ all these codes can some one help me n tell me whats wrong tps low brake fliud switch under volts g switch malfutcoin ecu interal mal f
pump malf speed sencor malf ?? anyone have a clue
gatorchin 11-13-2014 04:52 PM
Originally Posted by doityourselfMM
Are you getting any other codes? I was getting G Switch and ABS Pump failure codes simultaneously. Intermittantly. I kept resetting the codes and they kept reappearing. I replaced the G Switch and the codes kept on coming. *#@*! I ending up replacing the Controller Anitlock Brakes (CAB). Problem solved. $$$.... Hopefully, replacing your switch will help the 'old girl' out. Maybe a bottle of Ripple Wine will loosen her up. :D
I had g switch code along with a host of others related to the abs system..still trying to find time to try and fix the solder points on the module or get a new one if that fails.
The time now is 10:24 PM.
