Fueling problems? - JeepForum.com
post #1 of 7 Old 05-20-2013, 05:01 PM Thread Starter
corymonster
Fueling problems?
I had to take my jeep in for a smog check the other day and while it was in the shop i thought i might as well have them diagnose something for me. A couple days prior it would crank for a loooong time, or multiple times before firing during start-up. I was told it was the fuel pump. I saved myself $500 and swapped the pump myself with a Precision pump from O'Reillys.
It's still having to crank for a long time before it starts, then it has a rough low idle for a few seconds. If I floor it from standing, it literally stumbles for about 2-3 seconds before the wheels move. If I floor it on the freeway at speed, it downshifts, but doesnt really accelerate like it should. The RPMs go up, but the jeep doesn't really go anywhere with a sense of urgency. I swapped the filter about 10k miles ago. Where should I go from here? Is it starving for fuel, or is there something else i am missing?? its a 2002 limited w/ 4.7
corymonster is offline
post #2 of 7 Old 05-20-2013, 05:15 PM
99WJ539918
Have you checked the fuel pressure at the rail or at the pump? Any codes?
99WJ539918 is online now
post #3 of 7 Old 05-20-2013, 05:42 PM Thread Starter
corymonster
No codes, I have not checked the pressure. Is there a specific tool, or point where I should check? Thanks.
post #4 of 7 Old 05-20-2013, 06:55 PM
Galaxie500LTD
Fuel filter? TPS? IAC?
-I'm having some low idle issues, so I've ordered a TPS, hopefully that will fix things up for me. I've heard they can cause all kinds of problems. Maybe that's whats causing your troubles?
2001 WJ V8 QuadraDrive Stock
1966 Ford Galaxie 500 LTD, 390 CI (6.4L) V8 4V, two door hard top, black on black
Galaxie500LTD is offline
post #5 of 7 Old 05-21-2013, 06:33 PM
99WJ539918
You'll need a fuel pressure guage - attach it to the schrader valve on the fuel rail while cranking.
post #6 of 7 Old 05-22-2013, 03:35 PM Thread Starter
corymonster
The filter is about a year old, i might have to look into the TPS. but would that affect starting??
post #7 of 7 Old 05-22-2013, 03:35 PM Thread Starter
corymonster
Thanks. guess ill be goin to the store later
