fuel pump removal from spare tire wheel well - Page 3 - JeepForum.com
post #31 of 61 Old 10-09-2012, 09:36 PM
wvracer821
wvracer821's Avatar
i agree with everyone on just dropping it. i did it alone with a full tank once and its not that bad of a job. i would not have cut the hole but i was afraid of the damage i might do to the already rusted unibody and the jeep is my only way of transportation.
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #32 of 61 Old 10-09-2012, 10:03 PM
twinscrews
2003 WJ
So a little off topic but if you did cut the spare tire cavity out couldn't you make another to fit an over sized spare?
twinscrews is offline
post #33 of 61 Old 10-09-2012, 10:10 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Most people who cut out the cavity do it like this:
Leaving the diameter the same. I guess if you cut a bigger hole and fabbed up a whole new cradle, it could be done.
In the garage: M1 4bbl
McCloudsZJ is offline
post #34 of 61 Old 10-09-2012, 10:57 PM
85IrocZ-28
Dropping the tank is easy...8 bolts holding the skid on...just watch the length of the fuel lines and electrical.
I recommend setting a jack underneath the tank with a small section of wood (I used a 1 foot by 2 foot section of plywood). After the bolts were undone, I slowly lowered the jack with one hand while balancing the tank with the other.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #35 of 61 Old 10-09-2012, 10:59 PM
85IrocZ-28
This is a good idea...I like it. I may end up doing this in the future to build a square, and slightly larger tool box. I know that some people like to raise their tanks, but I haven't ever needed it to be higher and I like the internal storage.
post #36 of 61 Old 10-09-2012, 11:33 PM
BLACK04WJ
a motorcyce lift works even better than jacks
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #37 of 61 Old 10-10-2012, 04:17 AM
2001WJv8
2015 WK
gotta point one other thing out ... there is already some level of issue with WJ's and rear end collisions/fuel tank rupture/fiery results ... now I don't think it really rises to the level of a recall - BUT, if you do this, keep in mind you're providing a direct way to allow fuel spray into the cabin. fwiw
...and no chance your next of kin would win that lawsuit
2001WJv8 is offline
post #38 of 61 Old 10-10-2012, 06:00 AM
dr hook
...I slowly lowered the jack with one hand while balancing the tank with the other.
Says the people with 2 hands
I did a tank tuck last weekend, so now I can get to the pump REALLY easy
Lifted ZJ with stuff.
dr hook is offline
post #39 of 61 Old 10-11-2012, 04:28 PM
mperk12000
It is an easy job to drop the tank. The only reason I did it was to eventually do a tank tuck and neede the pump changed.
Pros- makes changing the pump easier.
Cons- road noise, air leaks
The biggest thing that worries me after doing the cut was how much structural integretiy I might have lost by doing it. Kinda hard to tell just from the pics, but that is a giant hole. Maybe not as big a deal as I think, but I worry when I get to flexing the whole area will be weaker.
mperk12000 is offline
post #40 of 61 Old 10-11-2012, 05:17 PM
2001WJv8
2015 WK
+1: cons = fiery death
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #41 of 61 Old 10-11-2012, 09:28 PM
pinky2252s
I have thought about cutting a hole, but I don't really think its worth it. I mean, there is a possibility of fumes, road noise, air leaks..... fire...
Dropping the tank is not that hard. And I may not ever have to do it on this car. And If I do, its most likely only going to be once in the life of the car.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #42 of 61 Old 10-12-2012, 12:27 AM
wvracer821
wvracer821's Avatar
I forgot to mention that i made a cover to go over the hole and sealed it up with some silicone so i don't get fumes and water inside the well. I didn't notice any difference in road noise once i put the spare back in there and shut the lid.
Junk: 2000 WJ, 4.0L
Build Thread:
post #43 of 61 Old 10-12-2012, 08:46 AM
85IrocZ-28
Where are all these mythical fiery death reports I hear people posting about...
JGC is the new Pinto, we're all going to die, we should all sue Chrysler...
I am sure it happens, but with what frequency and how does this compare to other vehicles? There are quite a few WJ's on the road, and I haven't ever heard of anyone on JF having problems.
I have a steel rear bumper an integrated gas tank skid. Behind that sits the factory 3/16 gas tank skid. I have no worries. Those that tuck their tanks should gain more protection from the rear structure of the Jeep. After you seal the floor area, I imagine it would be even safer than the factory location.
post #44 of 61 Old 10-12-2012, 10:36 AM
Merc1973
Just drop the tank.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #45 of 61 Old 10-12-2012, 11:25 AM
georged
wvracer821: Seeing that you did it, how about making a full size pattern of the tire well with the hole you cut clearly marked. I m sure there are some of us that would be willing to buy a copy
georged is offline
