fuel pump removal from spare tire wheel well - Page 2 - JeepForum.com
post #16 of 61 Old 10-09-2012, 03:00 PM
2001WJv8
2015 WK
Originally Posted by WJChris View Post
there is no space. Drop the tank is not a choice, its a MUST.
sounds like a challenge
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #17 of 61 Old 10-09-2012, 03:04 PM Thread Starter
somchhir1
challenge accepted....but I will be cutting a hole once its down to prevent dropping it twice...
somchhir1 is offline
post #18 of 61 Old 10-09-2012, 03:21 PM
alfaitalia
Glad I've got a CRD....... nothing in the tank but diesel.... no pump, no filter, no nothing!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #19 of 61 Old 10-09-2012, 03:39 PM
mperk12000
I cut mine out with the tank in. Just cut the entire tub out around the top lip. Then you can take a sheet of steel and cover it.
mperk12000 is offline
post #20 of 61 Old 10-09-2012, 05:35 PM
2001WJv8
2015 WK
that's cheating ... unless you lift/tuck the tank for clearance then it makes sense
2001WJv8 is offline
post #21 of 61 Old 10-09-2012, 06:15 PM Thread Starter
somchhir1
Attachment 486667
I'm liking this....looks like I might go this route...
post #22 of 61 Old 10-09-2012, 06:32 PM Thread Starter
somchhir1
Attachment 486667
what did you use to cut? I was thinking a air nibbler.
post #23 of 61 Old 10-09-2012, 06:54 PM
88yjproject
The only reason I would cut the spare tire well out is to do the tank tuck. You planning on putting a fuel pump in every year or what? Just drop the tank put one in and move on.
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline
post #24 of 61 Old 10-09-2012, 07:09 PM
offroad_monster
I had to replace mine and it was a pain in the a**!
offroad_monster is offline
post #25 of 61 Old 10-09-2012, 07:50 PM
itsparadoxical
Unless you run into problems where you need to drill out bolts for your skid or hitch mount, it is not a big deal to drop the tank. I ended up having to drill out and re-tap 3 of the 7 or 8 mounting bolts for my skid/hitch. But other than that, it is not a big deal.
Remove the hitch, disconnect filler tube and breather tube, disconnect electrical, disconnect fuel filter, take out the last few skid bolts, put the jack under the tank, remove stands, lower skid assembly. I had to order a new fuel line set from the dealer when I replaced my pump because the old connectors were so corroded at the pump. Be prepared for that possibility.
itsparadoxical is offline
post #26 of 61 Old 10-09-2012, 08:01 PM
wvracer821
wvracer821's Avatar
i did it....the tank is not even an 1/8th inch from the metal. be very careful. but it is possible. if you stay close to the lock ring on the pump you have a little more room to work. you can see my first test hole to the top right of the pump in the picture....yeah i got some plastic on that one but didn't go through.
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #27 of 61 Old 10-09-2012, 08:34 PM Thread Starter
somchhir1
thanks a lot...exactly what I was looking for....what did you cut it with?
post #28 of 61 Old 10-09-2012, 08:49 PM
wvracer821
wvracer821's Avatar
an air grinder..maybe not one of my best decisions but just be sure the tank doesn't leak anywhere. i started with a very small hole and just kept cutting until i got just enough to get the lock ring out. my tank skid/ hitch bolts were rusting bad enough that one of the nuts that are welded to the unibody twisted off and i didn't have access to a welder at the time to fix them so i didn't want to risk not being able to get the tank back up after i dropped it because i had to drive to work Monday morning after this one.
Junk: 2000 WJ, 4.0L
Build Thread:
post #29 of 61 Old 10-09-2012, 09:10 PM
doomi
I've had to drop my tank numerous times. It seems like its going to be more work cutting the hole with the tank there than dropping the tank.
As mentioned use a jack and stands to lower it, there's not much to it.
doomi is offline
post #30 of 61 Old 10-09-2012, 09:11 PM
gvos
Just drop the darn tank, why risk it and cut into the Jeep. Sorry I just think it's dumb. It's not that hard a job and yes I did it myself.
Had almost full tank and slid flywood on big floor jack to balance load and lowered it down. Half full or empty tank no sweat.
gvos is offline
