fuel pump removal from spare tire wheel well - JeepForum.com
post #1 of 61 Old 10-09-2012, 10:19 AM Thread Starter
somchhir1
Wj fuel pump removal from spare tire wheel well
I'm about to attempt to get to my fuel pump via my spare tire wheel well. Has anyone done this with pictures? the right tools, the wrong tools? i know that the tank is really close to the well so i'm trying not to pierce the tank. Any help is appreciated in advance.
Ryan
2001 WJ Laredo 4.0L
somchhir1 is offline
post #2 of 61 Old 10-09-2012, 10:22 AM
ChrisHager
Administrator
ChrisHager's Avatar
Seems a little dangerous to me...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #3 of 61 Old 10-09-2012, 10:26 AM Thread Starter
somchhir1
True, but i know its been done....and i'm determined to do it...for now and later issues...
post #4 of 61 Old 10-09-2012, 10:27 AM
ChrisHager
Administrator
ChrisHager's Avatar
I would drop the tank THEN cut the access hole for future work. Cutting with the fuel tank still there seems like a decent way to end up with a Darwin Award.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 61 Old 10-09-2012, 10:33 AM Thread Starter
somchhir1
I definitely see your point....having not dropped one before, and i've researched dropping it to death. since i'm doing it solo its got me looking for other options...
post #6 of 61 Old 10-09-2012, 11:02 AM
kfxnando
yep correct has been done before, and have also seen the pics, just can't remember where
self also need to do that same job, however due to all the work involved, haven't gotten around to it
sadly me will only do it when there is no choice, like when the jeep no longer goes
might of seen it on www.nagca. com
think that is the site
if I find it will post it
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
post #7 of 61 Old 10-09-2012, 12:50 PM Thread Starter
somchhir1
ok ... thanks.
post #8 of 61 Old 10-09-2012, 01:34 PM
2001WJv8
2015 WK
tons of threads describing this but didn't find any WJ pictures
here's one for a zj
http://jeephorizons.com/tech/zj_fuel_pump.html
the wj ones consensus seemed to be there is almost no clearance so it's very risky with tank in place...... ymmv
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #9 of 61 Old 10-09-2012, 01:43 PM
dr hook
I did it, and cut into my tank The tank sits AGAINST the floor of the tire well. The only way to do it without messing up your tank is to cut on the vertical sides of the well, but I'm not sure how you would reattach it.
plain ol 02 WJ.
dr hook is offline
post #10 of 61 Old 10-09-2012, 02:04 PM
cmp77
2003 WJ
Wow I seen that one coming
cmp77 is offline
post #11 of 61 Old 10-09-2012, 02:05 PM Thread Starter
somchhir1
here's one for a zj
thanks....right now i'm at a standstill...I cant decide....I really want to go through the top but if I can't, then I wont..i am hoping to find someone who has done it with a WJ..
post #12 of 61 Old 10-09-2012, 02:14 PM Thread Starter
somchhir1
ok....so I guess the answer is drop the tank...thanks guys...not looking forward to this...
post #13 of 61 Old 10-09-2012, 02:16 PM
2001WJv8
2015 WK
I think you could at least drill a hole to check clearance - just put a wrap of tape right at the end of the bit just far enough back to clear the thickness of the sheet metal but thick enough to stop the drill as soon as it clears ... that way you can actually see what kind of space you have and decide if its enough to use an angle grinder or cut off wheel etc ... maybe even enough to slide some flat steel in between?
i agree though, getting "blowed up" and put in the yearly darwin award doesn't seem all that great either....... you could always fill the tank with water to remove all the gas vapors (heck if you do it with the tank in place you'd probably be smarter to have it full of gas ... except there'd still be enough vapor at the top to cause some issues).
2001WJv8 is offline
post #14 of 61 Old 10-09-2012, 02:31 PM
pinky2252s
I never thought dropping the tank was too difficult. Hopefully your fuel tank is empty! I just use a combo of jacks and jack stands to lower it.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #15 of 61 Old 10-09-2012, 02:32 PM
WJChris
WJChris's Avatar
there is no space. Drop the tank is not a choice, its a MUST.
WJChris is offline
