Fuel issue - Page 2 - JeepForum.com
post #16 of 21 Old 06-09-2014, 09:38 AM
ChrisHager
Administrator
ChrisHager's Avatar
Carefully spray some carb starting fluid around the engine bay while it's idling. When you hear the RPM increase, you'll have narrowed down where your leak is coming from. Most likely, you have a cracked hose.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #17 of 21 Old 06-09-2014, 01:34 PM Thread Starter
pdxsport
Figured out where the leak is coming from fixed it hose had completely popped off. Just went out to start it and it did not start. Threw a p 0320 code 0320-No RPM Signal to PCM (Crankshaft Position Sensor Signal to JTEC)
A CKP signal has not been detected at the PCM. I read a little about the code. It looks like a may need a crank shaft position sensor? I going to go out and see if she wants to start now!
pdxsport is offline
post #18 of 21 Old 06-09-2014, 01:40 PM Thread Starter
pdxsport
Wont start at all now. Humming noise coming from the fuel pump area. Things seem to be going from bad to worse.
pdxsport is offline
post #19 of 21 Old 06-09-2014, 01:44 PM
ChrisHager
Administrator
ChrisHager's Avatar
Well, if it's bad, this may help: 2004 4.0 Crankshaft Position Sensor Replacement
Try unhooking your battery for a little while to reset everything and give it a shot first though.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #20 of 21 Old 06-09-2014, 02:36 PM
outofrng623
This just made me think about something...UGH,
I have to update my main thread and sorry I hijacked this one lol
http://www.jeepforum.com/forum/f310/...4/index27.html
outofrng623 is offline
post #21 of 21 Old 06-09-2014, 09:02 PM Thread Starter
pdxsport
Strange WJ fired back up first try,running strong. For how long?
pdxsport is offline
