Frozen Tie Rod Ends - JeepForum.com
post #1 of 18 Old 12-02-2013, 12:54 PM Thread Starter
bgohsman
Wj Frozen Tie Rod Ends
Hey all,
So, among everything else that I'm dealing with and replacing in my front end, I decided I might as well do the tie rod ends while everything is torn apart. However, the old ones are seriously rusted in there. I've soaked them with liquid wrench and let them sit overnight. I tapped on the crack in the tube with a cold chisel and hammer. No dice.
I have the feeling that this is probably fairly common and other people have dealt with it. Anyone have any advice apart from turning them red-hot with a torch and beating on them? I have four of these things to deal with.
Thanks,
Brandon
Brandon Gohsman
bgohsman is offline
post #2 of 18 Old 12-02-2013, 12:56 PM
jahcure
Replace that bar and save your self headaches
jahcure is offline
post #3 of 18 Old 12-02-2013, 12:58 PM Thread Starter
bgohsman
For some reason, I hadn't thought of that. I'd actually have to replace two bars. There is the one from the steering pitman arm to the passenger side knuckle. Then there is the connecting rod that goes from the passenger side to the driver's side.
God I hate rust.
Brandon Gohsman
bgohsman is offline
post #4 of 18 Old 12-02-2013, 01:12 PM
StrokedWJ
StrokedWJ's Avatar
x2. Both the drag link and the tie rod are relatively cheap. It could also be a good time to upgrade to the JKS or KOR HD versions if you plan on wheeling the WJ.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #5 of 18 Old 12-02-2013, 02:20 PM
JRobes
X3 on what was said about replacing the rods as well. I had to grab a torch and get the ends of the rods red hot and then clamp a vice grips on the rod and another on the tie rod end and step on both of them simultaneously to turn them in opposite directions to get it to budge. What I thought would be a hour long job turned into a 4 hour job and a trip to walmart for a torch. But, plus side is I now have a torch.
2004 WJ Overland, 4.7HO, Quadradrive, 3" OME HD/Bilstein lift
1999 Honda Magna VF750C
JRobes is offline
post #6 of 18 Old 12-02-2013, 02:31 PM
doityourselfMM
doityourselfMM's Avatar
And whatever you decide to replace, coat the threads with Anti-Seize, prior to installation.
doityourselfMM is offline
post #7 of 18 Old 12-02-2013, 03:44 PM Thread Starter
bgohsman
I coat nearly everything with anti-seize. Lol I avoid putting it on things such as lug nuts, however. ;-)
Brandon Gohsman
bgohsman is offline
post #8 of 18 Old 12-02-2013, 04:14 PM
mycreativename
My buddies all make fun of my excessive use of anti seize, but I'm never the one having to torch off any bolts anymore.
Sent from my blimp fortress using my carrier pigeons.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #9 of 18 Old 12-02-2013, 04:19 PM
skain8
skain8's Avatar
Best advice I've read on this forum in awhile.
I recently switched to the marine grade, which was recommended to me by a trusted friend. Good stuff.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #10 of 18 Old 12-02-2013, 06:14 PM
doityourselfMM
Your new tie rod ends will especially love you for that. And your lug nuts will be glad you didn't !
post #11 of 18 Old 12-10-2013, 10:04 AM Thread Starter
bgohsman
So, I did end up simply purchasing a new tie rod. That made that part of the job fairly mindless. And I slathered the ends in copper anti-seize (not that I expect I'll be doing this job again anytime soon).
Somehow, I dropped the ball and did not get the rod that goes from the pitman arm to the passenger's side. Fortunately, my leaking power steering fluid made the pitman side easy to get off. The other side...wasn't.
I soaked it with liquid wrench. I heated it for five minutes with a torch. I beat on it with a cold chisel and hammer. Eventually, I put the bar in two vices, side by side, put a pipe wrench on the tie rod end and beat the life out of it with a hammer. After about ten minutes of this, and constantly re-adjusting the vices, it moved. At that point, I put machine oil in the slit on the rod and continued beating. Some more oil, repeat. Once I'd made a full revolution with the oil, it started to get a lot easier. And, eventually...I won. lol
Brandon Gohsman
bgohsman is offline
post #12 of 18 Old 12-10-2013, 10:19 AM
scoomscoom
i hate having to replace the tie rods its always a chore but the acetylene torch makes it easy
2001 grand cherokee 4.0l 4inch lift 33x17s
242j transfer case for sale or trade for 242wj
scoomscoom is offline
post #13 of 18 Old 12-13-2013, 12:42 AM
Davidson82
Summit racing. I bought two tie rod ends and the bar all moog. 87.00 dollars US.
Davidson82 is offline
post #14 of 18 Old 12-13-2013, 04:49 AM
Prickett10
I lost the tip of my middle finger removing a driver side tie rod. That was rather unpleasant. Anti seize is your friend.
Better to be mute than dispute with the ignorant.
Perversion or self exploration isn't the point in this case.In fact there will be no case, no trial by a jury of our peers just fear in the hearts of those we choose. Doing this for the knowledge of our victory, that is how we are different.
Prickett10 is offline
post #15 of 18 Old 12-13-2013, 06:28 AM
dcorn
Rock Auto is also your friend. The replacement bars are actually more beefy than stock.
2014 Jeep Grand Cherokee Summit
dcorn is offline
