Front Half Shafts - Page 2 - JeepForum.com
post #16 of 20 Old 03-22-2010, 08:58 AM Thread Starter
D-roc84
im looking at Timken / Wheel Bearing/Hub Assembly-Front anyone ever buy from timken?
D-roc84 is offline
post #17 of 20 Old 03-22-2010, 12:21 PM
kadetklapp
1997 XJ Cherokee
Timkin is industry standard stuff. Never had any trouble with it.
Is there a write-up on this procedure?? My WJ is making some severe howling up front and it definitively needs new front shafts.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #18 of 20 Old 03-22-2010, 01:01 PM
Virmagicus
Virmagicus's Avatar
http://www.jeepforum.com/forum/f13/h...w-pics-377208/
Jeff
Virmagicus is offline
post #19 of 20 Old 03-22-2010, 01:07 PM
Jeeeeepster
How much are you looking to spend on hubs? i got a brand new pair for $90 off ebay. Their the cheapest ones ive found so far. heres the link if you wanna look. PAIR JEEP GRAND CHEROKEE FRONT WHEEL HUB BEARINGS 99-04 : eBay Motors (item 290391646879 end time Apr-14-10 18:28:56 PDT)
Jeeeeepster is offline
post #20 of 20 Old 03-22-2010, 01:22 PM
Virmagicus
Virmagicus's Avatar
Before you go buying hub bearings you may not need, do this check. Get the front tires off of the ground see if you have any play at 6 and 12 o'clock. You don't need to pry with anything either. If you have no play your hub bearings are good. If you have ANY play they are bad and need replaced.
Jeff
Permanent removal of front half shafts arch007 ZJ Grand Cherokee Forum 7 08-27-2008 05:59 PM
xj half shafts Dillonzj ZJ Grand Cherokee Forum 14 05-27-2008 06:12 AM
New U-joint half shafts? Reswob ZJ Grand Cherokee Forum 19 03-25-2008 11:55 PM
front zj u-joint axle shafts a direct swap for cv axle shafts? bjl95mustang ZJ Grand Cherokee Forum 12 05-19-2007 05:57 PM
CV Half Shafts - brands, experiences kellen ZJ Grand Cherokee Forum 8 10-23-2005 01:47 PM
