Front Half Shafts - JeepForum.com
post #1 of 20 Old 03-16-2010, 04:23 PM Thread Starter
D-roc84
Front Half Shafts
My front half shaft went today whos a good seller for them?
D-roc84 is offline
post #2 of 20 Old 03-16-2010, 05:37 PM
tkc
I'd like to know too. The CV Boot on mine must have torn off cause it's gone.
I went to Autozone and they have them for around $70, but the system there says that it's "critical" that you have the engine balanced when replacing these??
tkc is offline
post #3 of 20 Old 03-16-2010, 05:45 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
RockAuto Auto Parts
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #4 of 20 Old 03-16-2010, 06:34 PM
bigbill888
Engine balanced?? Nonsense.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #5 of 20 Old 03-16-2010, 07:14 PM Thread Starter
D-roc84
engine balanced? 4 balls poped outta mine dont feel bad haha!
D-roc84 is offline
post #6 of 20 Old 03-16-2010, 07:17 PM Thread Starter
D-roc84
How is that rockauto sells good stuff?
D-roc84 is offline
post #7 of 20 Old 03-17-2010, 11:14 AM
SJZ
SJZ's Avatar
When you go to the site, it usually lists several brands for each item. The Cardone half shafts are new units, made in China. I've used them many times without a problem. Fit and finish are very good, comes complete with tone ring, & nut. Knock the tone ring off the old axle before you toss it. It's nice to have a spare lying around.
-Steve
SJZ is offline
post #8 of 20 Old 03-17-2010, 07:08 PM Thread Starter
D-roc84
Ok thanks alot for the help is there anything else i should replace why im doing the half shafts or look for??
D-roc84 is offline
post #9 of 20 Old 03-17-2010, 07:10 PM
Jeeeeepster
check your hubs, cause you have to take them off anyways to take the halfshaft out. I replaced one of my hubs and a halfshaft in one setting.
Jeeeeepster is offline
post #10 of 20 Old 03-17-2010, 07:27 PM
sherker55
Once you get used to their site, you will never use another supplier! They kick a$$, and their prices are usually really good. They carry all major brands for OEM replacement parts, and then some!
sherker55 is offline
post #11 of 20 Old 03-18-2010, 12:43 PM
SJZ
SJZ's Avatar
Check your brake pads.
When re-assembling, make sure you use some type of anti seize compound (i.e. Never-Seizeô) where the hub fits into the knuckle, and for the hub mounting bolts. You'll know why when you go to dis-assemble it.
-Steve
SJZ is offline
post #12 of 20 Old 03-21-2010, 09:29 PM Thread Starter
D-roc84
has anyone got any hubs from rockauto? just wanna get some tips on what to buy
D-roc84 is offline
post #13 of 20 Old 03-21-2010, 11:23 PM
Darthteddy
1955 M-38
Advance Auto Parts sells the shafts for pretty cheap with a life time warranty. Anytime you mess them up or just feel like changing them if a boot breaks they will give you a new one no question.
Just my $.02
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #14 of 20 Old 03-22-2010, 03:47 AM
TMCXJ
yeah, but if you don't have a receipt for getting your engine balanced, the warranty's no good.
...just kidding.
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
post #15 of 20 Old 03-22-2010, 08:32 AM Thread Starter
D-roc84
what about the hubs on rockauto for 99 wj?
D-roc84 is offline
Permanent removal of front half shafts arch007 ZJ Grand Cherokee Forum 7 08-27-2008 05:59 PM
xj half shafts Dillonzj ZJ Grand Cherokee Forum 14 05-27-2008 06:12 AM
New U-joint half shafts? Reswob ZJ Grand Cherokee Forum 19 03-25-2008 11:55 PM
front zj u-joint axle shafts a direct swap for cv axle shafts? bjl95mustang ZJ Grand Cherokee Forum 12 05-19-2007 05:57 PM
CV Half Shafts - brands, experiences kellen ZJ Grand Cherokee Forum 8 10-23-2005 01:47 PM
