Front growl Left turns - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Front growl Left turns
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 10-25-2010, 07:03 PM   #1
srode
2008 XK Commander
Hey,
My 99 Grand is growling when making hard left turns. It doesn't do it turning right, but does left. Not immediately but after 10 to 15 feet it starts growling. Its not lurching like it's in 4WD just making a noise. CV boots are in good shape. It has quadra drive, is it the viscous coupling engaging? CV joint? Bearing? Suggestions on things to look for? It sounds like it's coming from the front.
Thanks, Steve
2008 XK Commander Limited 4.7 Quadra Trak II
1999 Jeep Grand Cherokee 4x4 Quadra Drive 4.7 L 163,000 miles(sold)
2004 GMC SLT Crew Cab 4x4 Duramax Diesel
1969 Camaro Pace Car
1969 Camaro Hard top
91 Cherokee - sold at 188,000 miles, still runing great at 250k last report
srode is offline   Reply With Quote
Unread 10-25-2010, 07:09 PM   #2
801DubJay
Have you changed your right tie rod end recently? I ask because I had a similar problem when I bought a tie rod end that wasn't contoured correctly & it would rub against the stock, right rim on left turns.
'00 WJ Laredo V8 aka Katie
My Build Thread: http://www.jeepforum.com/forum/f197/801dubjay-build-thread-1114628/
801DubJay is offline   Reply With Quote
Unread 10-25-2010, 07:11 PM   #3
srode
2008 XK Commander
No front end work - 160,000 miles and it's still all original believe it or not - still tight too.
