Front end roar and intermittent wobble - JeepForum.com
post #1 of 15 Old 05-04-2012, 07:41 PM Thread Starter
Bkhager
2011 JK Wrangler
Can anyone help me narrow down a situation? 1999 wj full time, 135,000 miles. A roaring noise starts up front around 35 mph, and you can hear it over the radio. I've also noticed that the front end wobbles intermittently. It comes and goes....... What gives?
Thanks in advance for any insight!
Hebrews 2:9
http://www.bethanybaptistmissionary.org/
Bkhager is offline
post #2 of 15 Old 05-04-2012, 08:01 PM
alwaysHI
2003 WJ
is it lifted?
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #3 of 15 Old 05-04-2012, 08:45 PM Thread Starter
Bkhager
2011 JK Wrangler
No sir, it is a stock vehicle
Hebrews 2:9
Bkhager is offline
post #4 of 15 Old 05-04-2012, 08:57 PM
ibreb3
Possible hub/wheel bearing? Get it to the speed it makes the noise, then slightly swerve back and forth, if the noise gets better steering on way and worse the other then it's prob a hub or bearing. Btw if so it will be on the opposite side of the turn that makes it worse, ie. if going to the left makes it sound worse the problem will most likely be on the right side. Hope this helps.
ibreb3 is offline
post #5 of 15 Old 05-05-2012, 08:29 AM Thread Starter
Bkhager
2011 JK Wrangler
I went out this morning and pulled off the front wheels. I didn't see/hear/feel anything off. So I rotated the tires (there is one odd tire in the group). I didn't notice any cupping, etc. I did adjust the tire pressure (they were all @20 so I bumped them up). I'm going over to Raleigh today so I'll try testing the wheel bearings.
Hebrews 2:9
Bkhager is offline
post #6 of 15 Old 05-06-2012, 12:55 PM
ibreb3
Just wondering how you made out?
ibreb3 is offline
post #7 of 15 Old 05-06-2012, 08:01 PM Thread Starter
Bkhager
2011 JK Wrangler
Well, I did the drive test, and the noise stayed constant. So I have no real idea where to to from here except to tear apart the front difff
Hebrews 2:9
Bkhager is offline
post #8 of 15 Old 05-06-2012, 09:00 PM
alwaysHI
2003 WJ
idk what your definition of wobble is, but it could be death wobble, shimmy, or bump steer. you just need to clarify.
as for the roar, read this:
http://www.jeepforum.com/forum/f310/...noise-1017597/
Build Thread -
SOLD
alwaysHI is offline
post #9 of 15 Old 05-07-2012, 06:51 AM Thread Starter
Bkhager
2011 JK Wrangler
It's hard to say what the wobble is, I've never had one do it before. I guess I'd characterize it as this sudden and mildly violent jerking of the steering wheel back and forth. It starts suddnely and end suddenly and I cannot make it consistently reproduce it.
As for the article, i think I'm going to agree with it (thanks a ton for posting that link). Yesterday I had the doors off of my JK and met my wife at my mother in laws. We left at the same time and I rode on both sides of her WJ at speed to see if I could hear anything. Of course, my mud terrains were loud enough, but I could not hear any noticeable roaring noise. So i guess my next step is to drop the axle and put it on the bench and rebuild it.
I'll let you guys know how that goes
Thanks!
Hebrews 2:9
Bkhager is offline
post #10 of 15 Old 05-07-2012, 08:24 AM
Justin_WJ
before you go tearing out the front diff, revert to the basics. No need for work to be done when it didnt have to in the first place.
take the front driveshaft out, if the roar disappears thats the culprit. most of the roaring ive experienced has been from the front driveshaft. Also, jack the front of the jeep up (with the front driveshaft out) and rotate the front wheels by hand. Better yet, have someone do it while you listen to the front diff. Then push and pull the top and bottom of the tires up front to see if you have play in the wheel bearings. Another possibility, check your T-case fluid level, mine was leaking fluid and made a roaring sound when it was low.
As for the wobble.....make sure all of your suspension bolts are tightened to the correct torque spec....bolts loosen over time. Im talking upper and lower control arms, Trac bar (especially), check for play in all of your tie-rods.
Hope this helps,
2000 WJ Limited, 4inch RC X, 242 T-case swap, 33x12.50 STT's, 15x8 D window wheels with 3.75 BS, JKS ADJ. Tracbar, T-case armor, Custom front winch bumper, Smittybilt XRC 8, 4.56's Extended Rola Rack w/Harbor Freight 6" lights, and always muddy :)
Justin_WJ is offline
post #11 of 15 Old 05-07-2012, 08:25 AM
narnwv
narnwv's Avatar
Roar that starts at 35-40 and doesn't change tone = unit bearing.
~Aaron
narnwv is offline
post #12 of 15 Old 05-07-2012, 05:48 PM Thread Starter
Bkhager
2011 JK Wrangler
Ok, I took the front driveshaft off and drove it around the block. The noise did not decrease (it might actually have increased a little). So I put it back and and have come to the conclusion that the front carrier bearings need to be replaced. According to the carfax on this vehicle, the PO had the front pinion seal replaced. I believe he had his local mechanic do the work. I have my suspicions that things "might" not have been done correctly. I guess my saying is true "just because you CAN call yourself a mechanic, does not mean that you SHOULD". Sooooo, it looks like I'm going to be assembling all the parts to rebuild the front diff. I'm going to take my time, do some research and do this myself (I've got experience rebuilding huge gearboxes for industry, as well as aligning equiptment, so I know my way around a dial indicator, etc). I'll probably be doing this in about three or four weeks, so I'll check back and let you know. Once again, I appreciate each and every one of you guys who took the time to work with me on this!
Hebrews 2:9
Bkhager is offline
post #13 of 15 Old 02-09-2015, 03:27 PM
Satrebil
Bump steer is less common in solid axles, correct?
Satrebil is offline
post #14 of 15 Old 02-10-2015, 10:51 AM
mustang125
2003 WJ
I would check your wheel bearings. If you lift the front wheel and try and rock it top to bottom and side to side I think you will find it wobbles. Replace the bad wheel bearing or both bearings with Timken's bearings, brand name. I ordered them from auto geeks for $80 each with free shipping.
If you are going to keep the jeep stay away from the cheep import bearings.
mustang125 is offline
post #15 of 15 Old 02-15-2015, 05:32 PM Thread Starter
Bkhager
2011 JK Wrangler
Thanks mustang! I had two situations going on. Brake caliper was grabbing AND bad wheel bearing. Crazy stuff!
Hebrews 2:9
Bkhager is offline
