Front end questions - JeepForum.com
post #1 of 17 Old 09-26-2013, 12:05 PM Thread Starter
Blake10w
Front end questions
Today on my way to work the front end of the Jeep was wandering all over the road and I could hear the front tires intermittently screeching. I pulled over and removed the front driveshaft and got going down the road again with now wandering or any of the noises that were present before. Any insight at all is welcome.
Blake10w is offline
post #2 of 17 Old 09-26-2013, 08:05 PM
pinky2252s
Tie rods, ball joints, control arm bushings. Look at and test them.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #3 of 17 Old 09-27-2013, 11:23 AM Thread Starter
Blake10w
What would be the best way to go about testing them?
Blake10w is offline
post #4 of 17 Old 10-01-2013, 05:06 PM Thread Starter
Blake10w
Just to clarify, its not a "death wobble" type thing. Its intermittent pulsing vibes and the front end wandering all over the road. Without the front driveshaft it drives straight and true which leads me to believe its something in the transfer case or the front differential. Any input at all?
Blake10w is offline
post #5 of 17 Old 10-02-2013, 11:21 AM Thread Starter
Blake10w
Anyone?
Blake10w is offline
post #6 of 17 Old 10-02-2013, 11:34 AM
MuddyWJ
Have a friend turn the wheel back and forth quickly while you're under the front. Look for play in ball joints and tie rod ends. For the control arms put a pry bar in-between arm and frame. You should have a little movement in the bushings given their rubber but too much will cause wondering for sure.
MuddyWJ is offline
post #7 of 17 Old 10-02-2013, 11:47 AM Thread Starter
Blake10w
Everything looked looked fine and seemed tight in the front end. It feels as if the pulsing vibrating sounds are coming from the transfer case.
Blake10w is offline
post #8 of 17 Old 10-02-2013, 11:53 AM
MuddyWJ
If the vibrations went away with the removal of DS then that's one issue. The wandering would be either ball joints or control arm bushings. I suggest you get the driveshaft situated then reinstall. Then tackle the wandering. In my experience there doesn't seem to be a way the DS could cause or fix a wandering issue. Change the fluid in the TC if it grumbles. Make sure to use the correct fluid.
MuddyWJ is offline
post #9 of 17 Old 10-02-2013, 11:55 AM
MuddyWJ
Also the TC linkage could need an adjustment
MuddyWJ is offline
post #10 of 17 Old 10-02-2013, 11:57 AM Thread Starter
Blake10w
The vibrations and the wandering went away when the drive shaft was removed. I guess wandering is not really a good word choice. It's more of a all of a sudden My jeep wants to drive me off into a ditch.
Blake10w is offline
post #11 of 17 Old 10-02-2013, 12:00 PM
MuddyWJ
Check the calipers and wheel bearings.
MuddyWJ is offline
post #12 of 17 Old 10-02-2013, 12:05 PM Thread Starter
Blake10w
I just put new rotors and calipers on it just a couple of days ago. I recently changed the fluid in the front differential and what little oil was left was no longer oil just sludge.
Could it be something in the front diff causing the sudden change in direction.
Blake10w is offline
post #13 of 17 Old 10-02-2013, 12:42 PM
85IrocZ-28
If it happened after changing your diff fluid and front brakes, I would look there.
Is the front diff a Varilock, and if so, did you add Friction Modifier? And is it only pulling in one direction? Do the brakes take longer than normal to release after you come to a stop? Are you missing any bolts, I would inspect the calipers.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #14 of 17 Old 10-02-2013, 04:21 PM
Duh
If you have good jackstands, try to put them under the axles and reproduce it where you can now see and hear the underside.
Duh is offline
post #15 of 17 Old 10-02-2013, 09:40 PM
tim0
What kind of shape is the drive shaft in?
Are the u-joints binding or is the CV locking up?
Check it out while you have it out.
tim0 is offline
