Front end noise at low speed decelerating - JeepForum.com
post #1 of 3 Old 03-04-2013, 06:47 AM Thread Starter
Hotroddn19
Hello,
I have a quick question, pretty sure I know the answer, just want to double check! I have a 2000 WJ limited, 4.7, 4x4. When cruising my front axle is quiet, upon decelerating at low speeds I am hearing a knocking noise. Sounds like a CV joint? No noise under a load accelerating, or at high speeds, just low speeds decelerating. Any thoughts?
Thanks
Andrew
Hotroddn19 is offline
post #2 of 3 Old 06-19-2013, 11:11 PM
marcram
2008 WK
Did you figure it out?
marcram is offline
post #3 of 3 Old 06-21-2013, 12:35 PM Thread Starter
Hotroddn19
Yes I did. Passenger front axle shaft had a bad cv joint. Upon closer inspection I found a tear in the boot. Replaced both axle shafts for $100 in parts. The core charge for the axles was more than the parts!
