Front end crunch and clunk noise - JeepForum.com
post #1 of 5 Old 01-20-2011, 07:06 PM Thread Starter
skreeks
So I got a 2000 laredo 6 cyl. and have this noise in the front end. If i slowly go over a dip or bump on the road. I hear a sort of crunching or rubber on rubber sound from passenger side. If I go faster over those dips and bumps it makes a hard clunk on the drivers side. Put new shocks in last week but no fix.Its had tie rod ends replaced,drag link adjustings, drag link tie rod ends, and new left outer cv axel. All bushings look tight visually. Jacked it up on frame and body to try and move suspension around and no play to be seen. Jumped up and down on front end and can't match that noise. Any one help me out here? May replace coils next.
skreeks is offline
post #2 of 5 Old 01-20-2011, 07:12 PM
Gazaway
Mine did it, replaced shocks and it went away...
Gazaway is offline
post #3 of 5 Old 01-20-2011, 07:52 PM Thread Starter
skreeks
Well I replaced the front shocks and the noise is still there. Replace the rear as well cuz it had a clunking noise too, but the new shocks fixed that>
skreeks is offline
post #4 of 5 Old 01-20-2011, 07:53 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
My track bar bushing seems to be squeaking when i went over bumps b/c it was cold.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5 of 5 Old 01-21-2011, 01:21 AM
blazepsi
Try tightening your Sway Bar Endlinks. Thats what happened with mine after some minor offroad.
blazepsi is offline
Banging/Clunk/Slam Noise at Highway Speeds v2 befumo WJ Grand Cherokee Forum 6 11-23-2010 03:17 PM
intermit. clunk in front noeffort WJ Grand Cherokee Forum 4 09-27-2010 06:06 PM
2000 WJ Rear Clunk Noise Bubba3200 WJ Grand Cherokee Forum 3 09-11-2010 10:34 PM
Suspension crunch dsl55 WJ Grand Cherokee Forum 11 05-14-2010 02:22 PM
01 Wj Clunk Noise! Help! dinoriggin WJ Grand Cherokee Forum 15 03-17-2010 04:07 PM
