Front driveshaft - JeepForum.com
post #1 of 20 Old 01-13-2013, 04:42 PM Thread Starter
outbackmatt
Double Cardan - Rezeppa Front Driveshaft Failure
After I installed a 3" lift, my double cardan - rezeppa front drive shaft started squealing bad. Its annoying on road and keeps getting worse. I read about them online and just want to make sure I get the right parts to convert to a better driveshaft. I have the nv242. Many thanks.
outbackmatt is offline
post #2 of 20 Old 01-13-2013, 08:51 PM Thread Starter
outbackmatt
Is it correct to assume a loud squeaky drive shaft is a sign of it going bad? The 4wd still works and the boot on the rezeppa joint is fully intact. Also I'm confused if I have the desirable front ds or not because I read how bad rezeppas are when the jeep is lifted. Then I read this from another web site saying the style I have does not need to be changed. So which is it and why and how do you make the ds stop squeaking?
The WJ Grand Cherokee comes with several different style driveshafts, some come with a standard CV at the transfer case and a U-joint at the axle, this is good and if that’s what you have, you don’t have to change anything. Others come with a CV at the transfer case and a Rezeppa type joint at the axle. If your front driveshaft is this style and you are lifting it, you will need to purchase our WJ Driveshaft Conversion part # RD-DS01-WJ. There are some WJ’s with a Rezeppa at both ends of the driveshaft, if your vehicle has this style you will need to buy the Rusty’s Driveshaft Conversion as well as the optional transfer case yoke. All these driveshaft conversions and parts can be found on Rusty’s Driveline Page.
post #3 of 20 Old 01-13-2013, 09:01 PM Thread Starter
outbackmatt
I have the one pictured second.
post #4 of 20 Old 01-13-2013, 09:06 PM
Ffrh911
Hmmm i thought the double cardan was the good one?
Ffrh911 is offline
post #5 of 20 Old 01-13-2013, 09:26 PM Thread Starter
outbackmatt
Yeah I did too. Now I'm just confused about which to get and if I need different yolks for converting to a new ds.
post #6 of 20 Old 01-13-2013, 09:41 PM
whosyadadie02
the convential dbl cardan is the best to get the repezza will will bind and go bad after a while. the boot will rip one day and itll just be a mess
whosyadadie02 is offline
post #7 of 20 Old 01-13-2013, 09:51 PM Thread Starter
outbackmatt
Ok is the best cheap option to find one out of a junkyard? What else do I need for the conventional double cardan to bolt right in place of my old drive shaft?
post #8 of 20 Old 01-14-2013, 08:11 AM Thread Starter
outbackmatt
Does anybody know how you put a conventional double cardan in place of a double cardan - rezeppa?
Will mounting to the differential be the same and wont the transfer case need an adapter? With all the horror stories Ive read about rezeppa ds, surely someone knows how to convert them.
post #9 of 20 Old 01-14-2013, 10:27 AM
GrandPrix104
Any drive line shop will be able to do it for you. You may be able to buy the one you want from them and give them your old one as a core to ssave money. In Utah and several western states there is a company called Six-States that will do this for you. I bought the double cardan/u-joint shaft pictured #3 from them and replaced my repezza-repezza I had before. Also RockAuto.com has the parts to rebuild your repezza joints for approx $200 IIRC. As was already mentioned the repezza is a bad choice for offroading cause if it rips the boot you are screwed.
1999 WJ Grand Cherokee Limited 4.7l V8 164k
2012 KK Liberty Limited 3.7l V6
2009 G8 GT 6.0l V8
GrandPrix104 is offline
post #10 of 20 Old 01-14-2013, 04:08 PM
whosyadadie02
just go to a jy and get one from a 93-95 zj v8 ... itll fit and then just get the axle side yoke and ur set
post #11 of 20 Old 01-18-2013, 10:16 PM Thread Starter
outbackmatt
The good news is tonight when I pulled my squeaky front drive shaft out I realized it is actually the conventional double cardan. So my wj was lucky and given the good ds. The bad news is it is very squeaky and you cant move the U joints by hand with it off. They are stuck/hard to turn. Do shops rebuild these with new u joints?
post #12 of 20 Old 01-19-2013, 12:38 AM
texlurch
Swapping u-joints is simple.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #13 of 20 Old 01-19-2013, 03:20 AM
wjtank21
3rd one I made for mine
wjtank21 is offline
post #14 of 20 Old 01-20-2013, 09:36 AM
whosyadadie02
just go to the auto parts store and buy some new ones and swap them in its easy
post #15 of 20 Old 01-20-2013, 06:50 PM Thread Starter
outbackmatt
Got a write up for a novice for how to remove the u joints? I assume its like any other drive shaft.
