Front drive shaft trouble - JeepForum.com
post #1 of 12 Old 02-09-2016, 06:54 PM Thread Starter
hifooy07
Have a 247 transfer case on an 04 wj. front drive shaft is rzeppa on tcase side and u joint on differential side. From what I've been reading I can ditch the shaft for a double cardan on t case side and u joint on diff side but with my tcase being all wheel drive is this going to vibrate at highway speeds and can anyone verify I can swap the yoke on the tcase for the double cardan yoke? Thanks
hifooy07 is offline
post #2 of 12 Old 02-09-2016, 07:18 PM
weaselsmopar
Yes you can swap the CV joint to a yoke on the TC. That is a very easy swap. On to the vibration part it is possible that you could end up with a vibration if you don't already have one. Also not sure if you have lifted your GC or not.
weaselsmopar is offline
post #3 of 12 Old 02-09-2016, 07:29 PM Thread Starter
hifooy07
Yep CV is bad. 3rd one I'm on. It's lifted 2" I drive highway everyday so actually been running no front shaft but its killing me no 4wd.
hifooy07 is offline
post #4 of 12 Old 02-09-2016, 09:18 PM
yoffer
I wouldnt see a vibration being a issue just from changing out the front driveshaft. Most of the 02'+ WJ V8's came with the double cardan driveshaft.
yoffer is offline
post #5 of 12 Old 02-09-2016, 09:27 PM
RUBtjICON
Then I got unlucky. My 02 has cv
RUBtjICON is offline
post #6 of 12 Old 02-09-2016, 09:32 PM
yoffer
I believe it was a split year. Im running a double cardan driveshaft that came off a 2004 V8 model.
yoffer is offline
post #7 of 12 Old 02-09-2016, 09:33 PM
RUBtjICON
Awesome, thanks for the info.
post #8 of 12 Old 02-09-2016, 09:55 PM Thread Starter
hifooy07
All v8's are awd right? So looks like I can make this happen without to much worry. Part time or full time the drive shaft spins so I guess it wouldn't make a difference right?
hifooy07 is offline
post #9 of 12 Old 02-09-2016, 11:13 PM
86cj74.2L
86cj74.2L's Avatar
If your WJ isn't lifted no vibes. I've had 2 04 V8's with the cardan at the transfer case and a u joint at the front diff. Around 4" lift the angles seen sharp enough to have a custom shaft made with a cardan at each end to keep caster and camber correct.
86cj74.2L is online now
post #10 of 12 Old 02-09-2016, 11:26 PM Thread Starter
hifooy07
Only running 2" lift.
hifooy07 is offline
post #11 of 12 Old 02-09-2016, 11:44 PM
ranwhenparked
Newbie
ranwhenparked's Avatar
1982 CJ5
I put on a Carolina driveline shaft when I put the 3" on mine, decided not to wait for the rezeppa to fail.
'44 Willys MB
'47 CJ2A (2x)
'48 CJ2A
'53 CJ3B
'82 CJ5 Base
'04 WJ Laredo
ranwhenparked is offline
post #12 of 12 Old 02-10-2016, 05:39 AM
JMZ101586
Nope. There are 2wd as well as 242hd and 247 wjs.
Stable:
04 WJ Special Edition 4.7
98 Camaro SLP SS with LS2 swap
05 STS4 4.6 Northstar AWD
JMZ101586 is offline
