Front drive shaft conversion question - Page 3 - JeepForum.com
post #31 of 32 Old 01-03-2011, 03:35 PM Thread Starter
DaveRous
I had a shop put it in for me in the end, so I assume they got it right but I don't know for sure. They wouldn't warranty the work because I pulled the shaft and yolks off a parts jeep. I'll do the next one myself, but just didn't trust myself with snow on the ground to not mess something up and make it worse
I will say I enjoy how quiet the jeep is without the front shaft on, didn't realize how far gone the old shaft really was until I got it off.
DaveRous is offline
post #32 of 32 Old 01-03-2011, 04:35 PM
BlackShuck
At what MPH range are you getting vibrations? I just put in a JY shaft myself (from a JZ) and adjusted the pinion angle the best I could (eyeballing it). It kinda has some noise at lower speeds but when you get going they seem to go away.
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline
front drive shaft help sullivanpunk WJ Grand Cherokee Forum 24 12-15-2010 02:36 PM
Front drive shaft? Jason_alex WJ Grand Cherokee Forum 4 10-30-2010 01:35 PM
Front Drive Shaft Question Twospeed WJ Grand Cherokee Forum 2 07-29-2010 09:57 PM
VIBRATIONS! WJ front drive shaft conversion. Help 22remud WJ Grand Cherokee Forum 4 05-21-2010 07:38 PM
I need a new front drive shaft! FlipFlop425 WJ Grand Cherokee Forum 63 04-04-2010 11:55 PM
