Front drive shaft? - JeepForum.com
post #1 of 5 Old 10-30-2010, 11:33 AM Thread Starter
Jason_alex
Front drive shaft?
Hey guys, i am looking at lifting my jeep and i keep hearing that the front drive shaft will brake or fall off, do i need to worry about this i have the 2001 GC with 242 transfer case is there a easy way to tell what type of front drive shaft i have?
Jason_alex is offline
post #2 of 5 Old 10-30-2010, 11:58 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
How high are you planning on going? If you are planning on 4" or more then your drive shaft will probably fail eventually. I do not think it will break off pre sey but will give you vibrations indicating that the joint on the Xfer case is shot. some one correct me if I am wrong. Once it goes change it to a double carden shaft.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #3 of 5 Old 10-30-2010, 12:09 PM
danielsCJ
1982 CJ7
You should only worry about an AM driveshaft if your planning on serious crawling or going with a 4in lift or higher, Ive got a 3.5in lifted GC stock Driveshafts does just fine
danielsCJ is offline
post #4 of 5 Old 10-30-2010, 12:32 PM Thread Starter
Jason_alex
Im thinking 2-3" lift
post #5 of 5 Old 10-30-2010, 12:35 PM Thread Starter
Jason_alex
Im talking about a little mudding and tops of a 3" lift kit any one else make a good 3" lift kit besides IRO?
front drive shaft help sullivanpunk WJ Grand Cherokee Forum 24 12-15-2010 01:36 PM
Front Drive Shaft narnwv WJ Grand Cherokee Forum 9 08-31-2010 05:42 AM
New WJ front drive shaft KentuckyWJ WJ Grand Cherokee Forum 6 07-17-2010 04:07 PM
Front Drive Shaft? jamtoy WJ Grand Cherokee Forum 4 04-14-2010 05:05 PM
I need a new front drive shaft! FlipFlop425 WJ Grand Cherokee Forum 63 04-04-2010 10:55 PM
