Front "CV" driveshaft problems (newb) '99 GC - JeepForum.com
post #1 of 4 Old 03-31-2010, 11:12 AM Thread Starter
chaddiesel
My fiancee's jeep has a bad front driveshaft - CV boots on each end - 1999 Jeep Grand Cherokee 6cyl.
After much research on this forum I have found a few options to replacing the front CV driveshaft assembly. I need a little guidance as to what should be done.
I am all for doing it right the first time but I'm unsure which option to take. This jeep will never hit the trail and will never get a lift for the rest of it's life.
I have read about Carolina Driveline as well as Iron Rock Offroad, both having replacement driveshafts available. Is there an alternative? or, Is there a junkyard find that will do the trick?
Looking to exhaust all options before I decide. Thanks in advance.
chaddiesel is offline
post #2 of 4 Old 03-31-2010, 11:28 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Junkyard is going to be your cheapest option. You should be able to find a CV style shaft for less than $50.
~James
ezflip is offline
post #3 of 4 Old 03-31-2010, 12:14 PM Thread Starter
chaddiesel
Thanks,
Found a driveshaft at the local junkyard. They are delivering it to my work, hopefully it's in good shape.
post #4 of 4 Old 03-31-2010, 12:35 PM
LordHobbit
Check it out before you pay them.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
Front Calipers "Teves" or "Akebono"? jimmy328 ZJ Grand Cherokee Forum 10 07-25-2009 10:48 PM
Centre "Driveshaft / System noise" ? Bombed WK Grand Cherokee & XK Commander Forum 0 01-01-2008 01:54 AM
Lifespan of front driveshaft w/IRO 3" WJ lift dickensheets ZJ Grand Cherokee Forum 11 12-21-2007 01:57 PM
Can having 1 front uca 1/2" longer then the other cause problems with steering? bjl95mustang ZJ Grand Cherokee Forum 15 06-27-2007 03:19 PM
2" front driveshaft ? merkur92 ZJ Grand Cherokee Forum 11 01-14-2007 08:51 PM
