Front brake caliper slide pins are different - JeepForum.com
post #1 of 4 Old 08-23-2013, 07:16 PM Thread Starter
jeep03ss
2003 WJ
I have a 2003 Jeep Grand Cherokee. The caliper slides were frozen and I am replacing the bracket, boots and slide pins. The pins are different. One is round with a bevel on the end. The other is round with a flat side 180 degrees apart and a flat end. Which one goes in the top and which goes in the bottom. I have looked online in the repair manual searched forums etc. I can't believe no one has had this question before.
jeep03ss is offline
post #2 of 4 Old 05-14-2014, 04:31 PM
Chero2004
Wish to know if you find out the solution. I have the same problem. Which one goes on top ?
Chero2004 is offline
post #3 of 4 Old 11-17-2016, 10:12 AM
mathman1
2009 MK Patriot
Pin with Rubber Tip Goes on Top
I have found two places that have answered this for a Jeep Patriot. The pin with the rubber tip goes on top.
I would posts the url's but the site won't let me.
mathman1 is offline
post #4 of 4 Old 11-17-2016, 10:16 AM
steve_80
is the other side still assembled so you can check?
steve_80 is offline
