Front brake caliper anchor bolt size - JeepForum.com
post #1 of 13 Old 03-19-2013, 10:10 PM Thread Starter
pinky2252s
The bolt I am looking for is, what I call it, the caliper bracket bolt. Not the slide pin bolts, but the other pair. The FSM names them "Anchor bolts". One of the anchor bolts on my drivers side is slightly stripped and I want to replace it the next time I have my calipers off and I was looking for the size or part number, but I cant find anything. I looked all through the FSM and googled it for a good 20 minutes trying to find either a part number, or size of the bolt (along with thread type) and can't find anything. All of the parts diagrams I find seem to omit the bracket and bolts. Does anyone know the size of that bolt so I can order some new ones?
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #2 of 13 Old 03-19-2013, 10:19 PM
WJ4x4LIFE
P/N: 05012437AA $2.85 each
Front caliper bracket bolt "Akebono"
Front caliper bracket bolt "Continental Teves"
WJ4x4LIFE is offline
post #3 of 13 Old 03-19-2013, 10:25 PM Thread Starter
pinky2252s
Thanks!
Is it broken?
post #4 of 13 Old 03-19-2013, 10:26 PM
WJ4x4LIFE
Yup!
post #5 of 13 Old 03-19-2013, 10:30 PM Thread Starter
pinky2252s
Just got one for 5 bucks shipped. I'll be sure to ask you for my number needs.
Is it broken?
post #6 of 13 Old 05-28-2013, 07:26 PM
theRickYoung
I get nothing when I do a parts search on both those companies website.
theRickYoung is offline
post #7 of 13 Old 05-28-2013, 08:45 PM
WJ4x4LIFE
There is no company website that is spoken about in this thread? Could you explain a little more?
post #8 of 13 Old 05-28-2013, 09:14 PM
theRickYoung
Sure, you mention Akebono, and Continental Teves. I did a part number search on their website to look for the bolt and found nothing. Pardon my assumptions about finding this part on their websites. I am just trying to find the specific dimensions for the caliper mount bolt so I have one on had when I remove the stripped one, just in case it snaps and I have to replace it.
post #9 of 13 Old 05-29-2013, 07:15 AM
WJ4x4LIFE
Wj
Akebono - M12x1.75x5cm
Continental Teves -M12x1.75x5cm
post #10 of 13 Old 09-18-2013, 12:03 PM
jkilby18
dude thank you, none of my local dealers had these bolts. as im doing the akebobo conversion on my tj i didnt have these bolts to compare to at the local fastener store.
you sir are a life saver! even the dealer couldnt give me specs on the bolts
jkilby18 is offline
post #11 of 13 Old 10-17-2016, 10:33 AM
1996GrandCher
That is not the correct size on this bolt. It is a fine thread and that is not fine thread. I know cause I read this and went and bought the bolts from Fastenal and it was wrong!!!! And I have spent hours on the phone with Jeep to no avail on the correct size!! Really is irritating!!!
1996GrandCher is offline
post #12 of 13 Old 10-24-2016, 09:13 PM
andrewx12
The aftermarket part number is h800 from O'Reilly auto
Current repairs needed:
AT filter and fluid
andrewx12 is offline
post #13 of 13 Old 01-26-2017, 08:40 PM
roythomson
M12 x 1.25 x 45mm
roythomson is offline
