front axle not fully engaging? - JeepForum.com
post #1 of 4 Old 07-16-2013, 12:53 PM Thread Starter
rcwj04
Hello, so when in 4wd if the tires spin there is this grinding noise, similar to a locker clicking. I replaced the t-case as it was shot, the noise is still there but not as loud. So that leads me to the front axle. A friend of mine said it could be that the shift fork is worn out, or possibly a vacuum leak which is causing it to engage and disengage. Or there could be a problem with my front diff. Where should I start if its the shift fork thats worn out?
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #2 of 4 Old 07-16-2013, 01:06 PM
Jrboarder27
What 4 wheel drive system do you have, is it quadra drive, quadra trac 2, or select trac?
Jrboarder27 is offline
post #3 of 4 Old 07-16-2013, 01:16 PM Thread Starter
rcwj04
I have the 242 transfer case, so select-trac
rcwj04 is offline
post #4 of 4 Old 07-16-2013, 08:40 PM Thread Starter
rcwj04
bump
rcwj04 is offline
