-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   front axle not fully engaging? (http://www.jeepforum.com/forum/f310/front-axle-not-fully-engaging-1549757/)
rcwj04 07-16-2013 12:53 PM
Hello, so when in 4wd if the tires spin there is this grinding noise, similar to a locker clicking. I replaced the t-case as it was shot, the noise is still there but not as loud. So that leads me to the front axle. A friend of mine said it could be that the shift fork is worn out, or possibly a vacuum leak which is causing it to engage and disengage. Or there could be a problem with my front diff. Where should I start if its the shift fork thats worn out?
Jrboarder27 07-16-2013 01:06 PM
What 4 wheel drive system do you have, is it quadra drive, quadra trac 2, or select trac?
rcwj04 07-16-2013 01:16 PM
I have the 242 transfer case, so select-trac
rcwj04 07-16-2013 08:40 PM
bump
The time now is 01:18 PM.
