Front axle bad? - JeepForum.com
post #1 of 14 Old 03-09-2011, 04:16 PM Thread Starter
Guiness92
Front axle bad?
To start I have a 2001 grand cherokee with the 4.7. Ive had the whining noise for about a month so I decided to check the axles. The rear diff was dry so I added fluid and the noise was still there, so I checked the front. The front diff has alot of metal shavings caked around the plug when I pulled it out.
My question is, what are my options at this point. Should I try to rebuild it? replace it, or upgrade it? Not sure if rebuilding it is in my mechanical abilities lol.
Guiness92 is offline
post #2 of 14 Old 03-09-2011, 04:19 PM
AGDubyaJ
rebuilding is going to cost $500 - $800. its a very hard job that requires a lot of procise measurements. if you can find some WJ axles with matching gear ratios, thats your best bet.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #3 of 14 Old 03-09-2011, 04:23 PM Thread Starter
Guiness92
a local junkyard has an entire diff assembly with axles for 400 bucks with 114k miles on it. Does this seem about the right price range?
post #4 of 14 Old 03-09-2011, 04:30 PM
AGDubyaJ
you could find a better deal, in my local craigslist there is front and rear axles (D30 and D35 from a I6 WJ) for $300 obo. they are 3.73 ratio, i would jump on em, but im looking for a D44 rear. however, does that $400 include the complete axle housing? or just the inards?
AGDubyaJ is offline
post #5 of 14 Old 03-09-2011, 04:31 PM Thread Starter
Guiness92
the complete housing and all ready to bolt on but only with a 60 day warranty, its an extra 450 bucks for a 2 year warranty on it.
post #6 of 14 Old 03-09-2011, 04:32 PM
FirefightinWJ
I paid 300 for a 50k mile 44a with an open carrier.
It had a ton of surface rust being from western PA, so it took some time with a wire wheel to clean up. I wouldn't pay much more than that though.
Junkyard parts vary by location though. Search car-part.com and see what you come up with.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #7 of 14 Old 03-09-2011, 04:36 PM
AGDubyaJ
it might be worth $400, what gears are in it?
AGDubyaJ is offline
post #8 of 14 Old 03-09-2011, 04:50 PM
Twospeed
What makes you think it needs replaced? Take the cover off and check the gears and pinion. It might just need new fluid or maybe just bearings. A lot cheaper than a whole new axle. If your rear axle was truly dry, it most likely will need new axle bearings at a minumum along with the seals (the fluid had to get out somewhere.) I had a whine from my rear axle until I replaced the axle bearings and seals. It's gone now. Not a difficult job to do and the whole thing with parts and having the bearings pressed on was about $120.
"Driver has no money, he owns a jeep."
Twospeed is offline
post #9 of 14 Old 03-09-2011, 05:32 PM Thread Starter
Guiness92
when I removed the plug on the front diff, there was alot of metal shavings gooped up around the fill hole. It could just be the bearings but would the metal shavings most likely be from the gears grinding down?
The rear was totally dry yes. Not sure where it leaked from though, I removed the rear diff cover, rotors and everything and there was absolutely no buildup anywhere of any sort. everything was perfectly dry aside from rust but I live on the jersey shore so thats expected. The axle spun freely with no noise and no slop or wobble. Im still confused as to why it was bone dry.
post #10 of 14 Old 03-09-2011, 05:49 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by Guiness92 View Post
...The rear was totally dry yes. Not sure where it leaked from though, I removed the rear diff cover, rotors and everything and there was absolutely no buildup anywhere of any sort. everything was perfectly dry aside from rust but I live on the jersey shore so thats expected. The axle spun freely with no noise and no slop or wobble. Im still confused as to why it was bone dry.
What about the pinion seal area?
Wheelin98TJ is offline
post #11 of 14 Old 03-09-2011, 06:01 PM Thread Starter
Guiness92
hmmm lol this is going to sound stupid but I didnt check that for some reason. I automatically assumed it was the axle bearings or a problem in the diff, didnt think of looking on the other side of the diff. That is most likely where that leaked out from.
Now I just hope the front axle is as simple.
post #12 of 14 Old 03-09-2011, 09:36 PM
skiebuster
Ghost fluid...only came in a few Jeeps...
skiebuster is offline
post #13 of 14 Old 03-09-2011, 09:45 PM
Twospeed
What do you mean by dry? No fluid in the axle?
Twospeed is offline
post #14 of 14 Old 03-31-2011, 04:06 PM Thread Starter
Guiness92
on the rear the diff was bone dry, but around the axle bearrings was dry too, I didnt see the need to pull the rear axle bearrings after I found the problem with the front differential though. Judging by the buildup around the pinion area on the rear Im almost positive the rear one leaked from the pinion seal.
The front one I think is the main problem. Im going to try to take it apart this weekend. Anyone know of a good writeup for rebuilding a front rear? lol I may be getting in over my head on this one but I cant afford to bring it to a shop
emptying out front axle RKOTAREK WJ Grand Cherokee Forum 4 02-13-2011 08:59 AM
99 GC front axle is loose? cautionneeded WJ Grand Cherokee Forum 3 02-01-2011 02:22 PM
Front Axle Seal theskier74 WJ Grand Cherokee Forum 12 12-09-2010 02:51 PM
Front axle leak V8 Grand WJ Grand Cherokee Forum 9 09-19-2010 05:51 PM
WJ V8->I-6 front axle swap dkpulsford WJ Grand Cherokee Forum 3 05-17-2010 01:02 AM
