Fourth Wheel Bearing in Over a Year, Is Something Else Wrong? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Fourth Wheel Bearing in Over a Year, Is Something Else Wrong?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Bds fox ipf 2.0 racing series shocks now available at rockIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-28-2012, 12:01 PM   #1
WheeliePro
I searched and found a similar post, but realized after I replied that it was in the ZJ Forum.
I have a 2002 Grand Cherokee Laredo 4.0 with 150k. I have replaced the front, drivers-side wheeling bearing 4 times in about a year and half. The first one was a faulty Duralast bearing from Autozone and needed to be changed within 2 weeks. Autozone exchanged it for a another Duralast. The second one lasted about 6 months and I asked for my money back, rather than another Duralast. I went to O'Reilly's and bought a Master Pro bearing that lasted about 6 months. When I replaced the Master Pro a few months ago, I forgot where I bought the last one and bought a Duralast with the intent on taking back the bad one. I realized my mistake after it was installed and I went to grab the old reciept. I know, I'm an idiot. And now the drivers-side is grinding again.
Before the Master Pro wore out, the passenger-side bearing went bad and I replaced it with the more expensive SKF bearing. I have had zero issues with the passenger-side since then (~9 months). I followed the manual exactly on all installations and always torqued the spindle nut. Is the drivers-side just a case of using crappy parts and getting crappy results? Or is there something else going on on that side?
WheeliePro is offline   Reply With Quote
Unread 03-28-2012, 12:49 PM   #2
TJSWJ
TJSWJ's Avatar
yep crappy parts, crappy results. I have use only timken bearings in the front of mine. Yes, i have to change them usually once a year, but i wheel it, and have oversized wheels and tires, so its expected. Good thing is they carry a lifetime warranty too, but you have to get them from Car Parts Warehouse. Autozone only gives 2 years on timkens now. But i see your in cleveland, so you should have a CPW local to you.
Also, the axle nut torque is critical in wheel bearing life. So be sure to use a torque wrench.
If your looking for some local help, check out xjor. Link in my sig.
www.xjor.org
TJSWJ is online now   Reply With Quote
Unread 03-28-2012, 12:55 PM   #3
billzcat1
Chicken in a Turkey Suit
2003 WJ
Yep, that's the long and the short of it. Couldn't have said it better myself.
billzcat1 is offline   Reply With Quote
Unread 03-28-2012, 02:13 PM   #4
WheeliePro
Thanks for the info. How expensive are the Timken's at CPW?
Unread 03-28-2012, 02:58 PM   #5
nickblack
Are you using a torque wrench when you install the bearing? Do not use impact gun to tighten.
nickblack is offline   Reply With Quote
Unread 03-28-2012, 03:02 PM   #6
WheeliePro
Yes, I'm using a torque wrench.
Unread 03-28-2012, 04:18 PM   #7
TJSWJ
TJSWJ's Avatar
i believe they are around 150-170 each.
www.xjor.org
