Fixed length track bar install...how difficult? - JeepForum.com
post #1 of 4 Old 03-31-2010, 10:49 AM Thread Starter
SouthernboyWJ
have an IRO fixed length track bar and need to know how easy or difficult it is. any tips to speed it up would be awesome as well
SouthernboyWJ is offline
post #2 of 4 Old 03-31-2010, 01:09 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
As long as it is the correct length, remove old one, put new one on. And make sure you torque the bajeesus out of it. Its really just as simple as that (as long as it is the correct length)
~James
ezflip is offline
post #3 of 4 Old 03-31-2010, 01:22 PM
mtnmarc
x2
its easy. just make sure you put the upper bolt on the same way as you took it off. otherwise you wont be about to "torque the bajeesus out of it" lol.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #4 of 4 Old 03-31-2010, 02:09 PM
TJSWJ
if for some reason it does not line up correctly put the upper bolt in and snug it up. with the jeep on the ground, wheels on, have a buddy move the steering wheel back and forth. this will move the body back and forth over the axle and help you line up the lower bolt into the axle. then torque both bolts to specs. make sure to measure from a given point on each tire to the body next to the coil spring. be sure that its the exact same distance on both sides and be sure to measure in the exact same spot on each side. if its not the same or dang close you may need and adjustable track bar
TJSWJ is offline
how difficult is it to install? lateralus3 ZJ Grand Cherokee Forum 15 11-23-2009 05:12 AM
ZJ 3.5" lift track bar length dmolaver15 ZJ Grand Cherokee Forum 3 07-24-2009 02:34 PM
Stock WJ track bar length Wheelin98TJ WJ Grand Cherokee Forum 5 06-30-2009 04:48 PM
Fixed DW by upgrading track bar to KOR durometer bushings QuadraTokn ZJ Grand Cherokee Forum 0 11-07-2008 01:31 PM
3in IRO lift, whats the proper track bar length? MEinSoCal ZJ Grand Cherokee Forum 7 09-04-2008 05:46 PM
