Fix your OEM Disc changer in less than 5 min - Page 2 - JeepForum.com
post #16 of 28 Old 08-13-2011, 10:00 PM
85IrocZ-28
I pulled mine apart and cleaned the reading eye, no success. I didn't know that there was a different optic to read where the disc is. If someone has a pic our can explain what to look for, I will give it a try again.
EDIT: I was on my phone and didn't see the image...now at a computer. I will try it again tonight.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #17 of 28 Old 08-14-2011, 05:34 AM
Gran_Paradiso
2015 Summit
Gran_Paradiso's Avatar
2017 WK
Let me know. I reached in last night wiped it off, loaded six discs and its working. Could be a fluke we shall see.
Sent from my DROIDX using JeepForum
Gran_Paradiso is offline
post #18 of 28 Old 08-14-2011, 06:15 AM
Ravie
I wonder if this is the same kind of issue with reading the CD's themselves as well. Mine loads the CD's just fine but skips like crazy on almost every CD regardless of whether it is scratched at all or not. Quite annoying. I'll have to get some long Q-tips and see if cleaning some things helps...
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #19 of 28 Old 08-14-2011, 02:24 PM
MadMonk
I tried this because mine hasn't worked in months, but even after cleaning the sensors all I ever get is "Err" on the head unit. I took the cover off so that I can observe what was happening. It looks like the disk finally goes in, but never spins up. Maybe a bad motor?
Here's a quick video of what I'm talking about.
'99 WJ Limited 4x4, 4.0L, Patriot Blue Metallic, IRO 3" springs, track bar, and rear sway bar links, Doetsch Tech 8000 shocks, Tenneco steering stabilizer, Carolina Driveline double-cardan front drive shaft.
MadMonk is offline
post #20 of 28 Old 12-19-2011, 05:58 PM
Jeff64
Got mine to work today.
My cd changer didn't work when I bought it this February. After reading the posts in Jeepforum, I went out and took another look at it. When I would try it before, I too would get the "error" messages. Today, I removed the magazine, and blew air into it-even though it looks very clean inside. I also moved the silver lever up and down a few times. When you do this, you can see the 1/4 inch black plastic gears turning while you move this lever up and down. I went up front and turned on the cd changer. I then re-installed the magazine. It then made a slight "clicking" sound as it tried to pull the first cd into the changer. I knocked on the side of the changer 1 or 2 times, and everything settled, and it began to play. I went back to the drivers seat and cycled through the various functions of the changer through the radio. It has worked ever since. Since the black gears are plastic, maybe at one time they "jumped" the silver lever. Who knows. I'm just glad I got this to work. Hope this trick works for someone else.
Jeff64 is offline
post #21 of 28 Old 12-19-2011, 06:29 PM
BigWheel7
what are these things you call a "cd"
BigWheel7 is offline
post #22 of 28 Old 12-19-2011, 07:25 PM
MudPit
Good info. I've actually done this with multiple changers over the years. Every used car I've owned seemed to have a filthy tape deck and changer. Cleaning the tape heads and cd lens is one of the first things I do. Gotta have your music!
__________________________________________________ __________________________
"I let the dogs out.
MudPit is offline
post #23 of 28 Old 12-19-2011, 09:33 PM
Gran_Paradiso
2015 Summit
2017 WK
I've not had a problem since I cleaned all the lenses back in August. I use it daily.
post #24 of 28 Old 12-20-2011, 10:17 AM
mctwin2kman
Ha, at least you guys have the cartridge. Mine did not come with one. Still not sure if I want to spend 80 bucks for one. So far that is the only price I could find. And I did not really look that hard. May just do the ipod mod so I can direct connect my Sirius unit.
mctwin2kman is offline
post #25 of 28 Old 12-20-2011, 10:32 AM
ChrisUT
you can get the whole changer with cartridge on ebay for 50-75 bucks:
http://www.ebay.com/itm/99-02-Grand-...item3cbeeaa938
http://www.ebay.com/itm/Jeep-Grand-C...item3f118cbc26
http://www.ebay.com/itm/99-00-01-JEE...item5d312162cb
they might not all have the cartridge with them, but better than getting it from the dealer.
ChrisUT is offline
post #26 of 28 Old 12-20-2011, 05:41 PM
Fishmoose
Wj
I'll sell mine for 75$ It works and comes with the cartridge.. s.musso@hotmail.com
Fishmoose is offline
post #27 of 28 Old 11-22-2014, 12:50 PM
gtg413i
2003 WJ
Good find. I used window cleaner and a q tip. I didnt exactly know where to celan and first time it didnt work. Then i just cleaned all around that area and it works now!
Brian's Black Betty Build:
gtg413i is offline
post #28 of 28 Old 02-28-2016, 04:41 PM
gtg413i
2003 WJ
I spoke to soon. I am still getting disc error. I tried 2 other ebay cd players and still get disc errors. I think either there is a power issue or these cd players are just getting old and failing. I will try another off ebay. I like throwing parts at the jeep.
gtg413i is offline
CD Changer Delete? billzcat1 WJ Grand Cherokee Forum 9 08-22-2010 06:00 PM
does my stock HU have changer capabilities? nickaplease03 WJ Grand Cherokee Forum 0 08-06-2010 05:59 PM
Yet another WJ cd changer question RTHemi2 WJ Grand Cherokee Forum 20 05-05-2010 11:24 PM
wj cd changer codycthn WJ Grand Cherokee Forum 3 05-02-2010 02:07 PM
anyone have a problem with the CD changer? edog WJ Grand Cherokee Forum 9 08-09-2002 07:49 PM
