First oil change! - JeepForum.com
post #1 of 15 Old 06-02-2013, 04:05 AM Thread Starter
cplack745
First oil change!
Alright so the first oil change is coming up sense I got her! What would you guys recommend for the 4.7 with only 79000 miles on her?!?
cplack745 is offline
post #2 of 15 Old 06-02-2013, 04:21 AM
Jer-Bear
I'd run through a cheap 10w-30 oil with Rislone additive for 1500 miles to clean it really well, then run through a part synthetic with Marvel Mystery Oil for 3000 to get everything running smooth and lubricated.
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #3 of 15 Old 06-02-2013, 11:34 AM
lvngtheJEEPlife
Rotella t5 or a high grade mobil 1.
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #4 of 15 Old 06-02-2013, 12:51 PM
KayCeeJeep
Just about any name brand full synthetic in 5w30 should clean up any residue and treat your engine well in the process. If you're not a synthetic guy, I'd suggest conventional Pennzoil 5w30 in the yellow bottle, it is higher in detergents than just about any other name brand oil so also a good choice if you're not sure how clean it is. Valvoline Maxlife is also very high in detergents and would be a very good choice as well as it also has seal conditioners which can't hurt for our aging WJ's.
KayCeeJeep is offline
post #5 of 15 Old 06-02-2013, 01:01 PM
Jer-Bear
But be careful with Pennzoil, it starts turning colors at about 1500 miles and you need to change it around 2000.
Jer-Bear is offline
post #6 of 15 Old 06-02-2013, 05:48 PM
KayCeeJeep
That's because it's cleaning, but that has nothing to do with how well it's lubricating Like I said it is higher in detergent than any other conventional, but oil can both clean and retain it's lubricating properties all at the same time.
You don't need to change it any sooner than anything else.
post #7 of 15 Old 06-02-2013, 07:27 PM
Jer-Bear
My man, I've ran Pennzoil in a new engine and it turns at 1500 miles. You're right, it is made of mostly detergents. That's why it breaks down faster than most oils.
Jer-Bear is offline
post #8 of 15 Old 06-02-2013, 09:29 PM
KayCeeJeep
Never mind...
post #9 of 15 Old 06-02-2013, 11:15 PM
pinky2252s
Run brand new oil in a car for 10 miles. Its gonna come out black. You cant tell how an oil is lubricating from its color..
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #10 of 15 Old 06-03-2013, 01:11 AM
Jer-Bear
Um, not unless you're using used oil...lol. New oil usually stays the clear yellow hue before being burned and broken down. Check under your hood more often.
Jer-Bear is offline
post #11 of 15 Old 06-03-2013, 04:21 AM
pinky2252s
Mmkay bud.
Is it broken?
post #12 of 15 Old 06-03-2013, 05:46 AM
lvngtheJEEPlife
Oh boy..
post #13 of 15 Old 06-03-2013, 07:21 AM
alfaitalia
Some of you must have some real clean engines! When I ran petrol (gas) engines I always run an engine oil flush through to get rid of as much dirt as possible before I change the oil andthe new oil is ALWAYS dark within a 1000 miles or so.... short of taking your engine apart and cleaning every part thats how it will be and is perfectly normal.
I run a diesel now....and its it new oil is black almost instantly...because diesel engines stay dirty no matter how you flush them. Does not stop the oil staying in for the full 12000 miles (that is the correct interval for a CRD before all you 3000 mile change gas engine owners have a heart attack!)
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #14 of 15 Old 06-03-2013, 10:16 PM
coloradowjowner
:thumbs up my 4.0 is virtually silent when I changed over to Rotella.
coloradowjowner is offline
post #15 of 15 Old 06-04-2013, 10:55 AM
Stimmel
i run mobil1 1 full syn in my 4.7 with the exact same mileage picked it up with 71k on it so yea 5w30 full syn high mileage works well for me
Stimmel is offline
