-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   FiancÚ Smash (http://www.jeepforum.com/forum/f310/fiance-smash-1585521/)
AJ1227 09-14-2013 01:18 PM
FiancÚ Smash
3 Attachment(s)
Hey guys,
Been so long since I posted I had to create a new account because I couldn't remember username/password and email was out of date! Sooo, my fiancÚ takes my jeep last weekend to run some errands and skids down a wall at the bank. Damage wasn't severe but enough to be annoying and I wanted everyone's input on possible fixes. (Pics attached)
Current Damage:
1. Scratched/scraped rear bumper (me a while back)
-I have Overland trim so all exterior colors match. It's also silver (tends to fade and hard to match) so I'm not sure how to fix this. I thought of buying a bottle to touch-up paint matching factory color but it was in an accident and rear bumper has been repainted once with body shop having trouble matching (I took it back the first time). Anywhere I could take a paint chip and have someone match the color with auto paint like Home Depot does for walls?
2. Broken passenger mirror glass, scraped housing
-Found new power/heated passenger mirror on eBay for $30- not a problem. I'm getting double vision with headlights on my drivers side mirror and want to fix that as well but powered/heated/auto dim glass only is hard to find and full housing with mirror is expensive (100-150) when what I have technically works. Anyone seen or fixed the double vision before?
3. Scratched/scraped passenger door handles
-Same as number 1 as far as touch up paint. I have seen chrome covers that are peel and stick but I'm afraid they may come off easily and I'm not sure if it will look stupid with chrome overload (wheels, grille, tow hooks, trim strips already). I like the thought of carbon fiber but it may look stupid with silver paint and I'm still worried of the adhesive failing. Anyone have the covers? How well do they hold? Thoughts?
4. Scratched/scraped lower door trim? (Not sure what its called, having trouble finding online)
-This is the wide cover trim at the bottom of the doors. Same as number 1 as far as touch up paint. I'm not sure what to do. If I went with carbon fiber handle covers I could also get the patterned wrap and cover this lower trim with it. Any thoughts?
Thanks for the input!
Thomahawk 09-14-2013 02:13 PM
Ha, i would also changed username if that happened to me, lol
SteelBlue_WJ 09-14-2013 03:12 PM
26 Attachment(s)
You know you could just trade her in on a newer model at this point
JRobes 09-14-2013 05:05 PM
^this. I'm VERY hesitant to let my gf drive my Jeep in fear of something like this happening. How women are capable of such things is beyond me.
dlundblad 09-14-2013 05:57 PM
One amazing thing about lady is that she loves cars as much as me. She is very cautious while driving and takes great care of them. She actually offered to let me drive her Volvo s60 before I let her drive my WJ. I felt so undeserving :eek:
As for the body work: I believe the mirrors are universal. You said you have Overland trim so was your Jeep originally a Laredo? If so it might just be a good excuse to upgrade to the heated mirrors. I believe they are just plug and play. I would avoid the $30 ebay ones though and try and find oem ones in a junkyard. I have a few friends who tried cutting corners with ebay mirrors. You know they brag how they spent on new what I spent on used.. then only to find their mirror glass to have fallen out one night while driving or the glass pivot points to loosen and allowing the mirror to jiggle over bumps.
As for the body trim try finding some matching patch up paint for now and just continue to look for matching trim. Once again, theres nothing wrong with a good excuse for junkyarding. :cheers2:
SteelBlue_WJ 09-14-2013 07:00 PM
26 Attachment(s)
I'm pretty sure they arent plug and play between the different types of mirrors, easiest to replace with same type of options on mirrors
when he said overland trim he likely meant he had the overland model, referring to it as a trim level like on most cars.
you could use this as an opportunity to paint the bumpers and cladding black and paint the wheel arches too in order to look like fender flares, I've seen it before on this forum and it looks sharp...
I still think you should trade in the GF on one that drives better, or keep that one away from your Jeep! i dont let mine drive mine anymore... now she can continue to wreck her 2012 Mazda and make it look like a 2001 the way she treats it and I could care less! lol
rdkendrick 09-15-2013 12:22 AM
Check the classified part-out section on here. Champ926 has a new Overland in. He probably has some mirrors. Maybe even door handles.
Sent from my iPad using my fingers
cykaaro 09-15-2013 12:36 AM
Actually, the mirrors are plug n play with some minor exceptions. If the door panels have courtesy lights, it uses a different harness from the mirror to the control module. Typically these are red from the models I've been in at the wreckers. If they have courtesy lights, it's yellow or green. one is passenger, one is driver. Can't remember what colour is which. Again, I've seen this on many at the wreckers. I have heated mirrors having the upgraded Laredo trim package, but no courtesy lights. I switched out that harness so that I could put in LED strips. All plug and play. The basic wiring haress will work on heated or none heated mirrors and is triggered by the defrost button for the heated mirrors. I've not seen heated/non-heated that don't interchange yet.
Dimming mirror though is a different animal. If the vehicle came factory with it, the wiring is there. You should be able to put a stock heated one in with no issues. However if you want to upgrade to a self dimming mirror and it didn't come with it, this is not possible. You'll have to hardwire it into your self dimming rearview mirror in order to work. Most auto dim rearview are by gentex. There is a wire that runs to the side mirror so when the rearview dims, the side mirror dims.
:cheers2:
veiri86 09-15-2013 12:52 AM
Originally Posted by AJ1227 (Post 16001793)
Hey guys,
Current Damage:
I would be very happy if my WJ had only these imperfections.
IMO just replace the mirror with a used one from the JY and live with the other scratches.
I have a bad experience with the new side mirrors from Ebay. Most of these mirrors when you install them and look at them, you will notice huge difference in the area covered by the mirror between the OEM and the new one from Ebay, in the new one from Ebay there is a huge area can't be seen by that mirror and it makes a dangerous big blind spot (Be Careful)
AJ1227 09-15-2013 03:16 PM
Thanks
Thanks for the info on the new eBay mirrors- I was just about to order the replacement. I will go junkyard parts on that.
FYI- my jeep is '04 Overland; I didn't just upgrade trim. My bumpers and handles match the body paint.
So, steering clear of new eBay mirrors seems like good advice but I also need a RB1 nav/radio and instrument cluster is a little wonky on the tach and speedo so I'm gonna buy used on eBay, $350 and $75 respectively unless someone knows where to get working ones for cheaper.
Anybody know about the handle covers I mentioned? I just have a feeling they aren't going to work properly.
I'd love to trade this one in on a new diesel but I need to find a used one before I can afford it. Got this one 3 yrs old with 24k miles, now have 147k. If it can last a couple more years...
cykaaro 09-15-2013 07:23 PM
I've always got my guage clusters for $25 at the wreckers pulling my own. Upgraded mine to the white gauge faces, as well as the the g/f.
AJ1227 09-16-2013 05:25 PM
Excellent advice- he responded to my text within minutes and found several things that I was looking for. He also has a silver overland coming in soon that may match my exterior parts. Fingers crossed!
The time now is 06:58 PM.
