few problems with my cherokee - JeepForum.com
post #1 of 4 Old 05-15-2013, 08:17 PM Thread Starter
BlueCobalt
ok first off i am new to jeeps, mostly had chevy sport cars (camaros monte carlos etc) all my life. so hello to everyone as this is my first post.
so i just bought a used 2004 jeep grand cherokee over land edition. i love the thing but i am having a few problems with it.
Problem #1. standard cruise control problem, will turn on but not engage. did some searching online and looks like the most common problem was a vacuum leak. i read that air will only blow through the defroster only and your cruise control light will say it is on but when you set it, it wont engage. but now with my jeep. i do get air through the floor to the defrost and my cruise control light will come on but will not set. i have checked all the fuses and they are all good and checked the vacuum lines and they appear to all be good as well but you never know, so i will have to check those more thoroughly when i have time. as i am moving to new orleans very soon i would love to have the cruise control working on the long drive.... so if anyone can help me with this problem i would be in your debt
problem #2. knock sensors are acting up and says i have an fuel leak (got the codes from turning on and off the key 3 times). now the check engine light came on one time after i gassed up not to long ago and i figure it was because i did not put the gas cap back on properly. but i have tightened the cap and put it on right but the check engine light is still on. is there a way to reset the codes? and i read online the knock sensor codes will come up if i am not using the correct gas (which yes i have been using the cheaper gas). the exact codes are P0325, P0330, and P0442
thanks in advance
BlueCobalt is offline
post #2 of 4 Old 05-15-2013, 10:21 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Greetings Blue and welcome to JeepForum.
The last year for XJ Cherokee production was 2001, so your 2004 is WJ model Grand Cherokee.
I'm going to move your thread to the WJ section where your fellow drivers are most likely to be able to assist you.
Don't forget to update the model info in your profile so people don't get confused, and good luck with the jeep!
***Chris***
chris87xj is offline
post #3 of 4 Old 05-15-2013, 11:34 PM
Schlotzky
2007 XK Commander
Since you have an Overland, your climate system does not use vacuum like the Laredos and Special Editions you were reading about i.e. a vacuum leak wouldn't affect your defrost/etc. I believe the cruise module is still vacuum operated, though, so it's still the primary place I'd look. Take a good look at all the vacuum lines. I think Jeep used the worse rubber they could find for their vacuum hoses as I've had to replace almost all of mine on my '04 while my previous three GMs (6, 8,and 9 years older) all still had original lines in great shape. I think you'll find Mopar does a lot of things different than GM does, if you haven't already.
You can reset codes by simply disconnecting the negative battery terminal for a few minutes and then reconnecting it. Vacuum leaks could very well cause codes as well.
Schlotzky is offline
post #4 of 4 Old 05-16-2013, 08:28 AM Thread Starter
BlueCobalt
ok thanks. ill check the tubes more closely today if i have the time. any chance you have a picture on hand of exactly where i should be looking on the overland? it seems my hoses come off the engine and head to the driver side, but i was reading a post about some hoses under the battery but i dont know if that is for my model since the battery is on the passenger side
